BORLA
Old 06-16-2013, 12:49 PM   #393
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The shifts heavily favor mph at wot. That's where the work needs to be done to get it right.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 06-16-2013, 03:03 PM   #394
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Man, tuning those automatics are insane lol. Much more prefer choosing when to shift myself.
John, I might hit the track Tuesday if I see that the DA is low. If I see similiar numbers as last time I will hold off. Thursday wont work for me either this week.
sent from my galaxy s3. that would explain the errors.
xjer22x is offline   Reply With Quote
Old 06-16-2013, 03:20 PM   #395
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Motion thanks for your comments, they've inspired me to poke around in my tunes.
So the 2nd to last tune, 1-2 was shift rpm wot 6000 and mph of 32 mph. Now tuner has changed to 25 mph. both were 6000 commanded.
2-3 was 59, now set to 57, and 6000 for old and new.
Where would I find the rev limiter in HTP, what drop down would that be? I'd like to see where it is, I bet it's 6300.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 06-16-2013, 06:08 PM   #396
Motion427
Drives: 2010 2SS/RS Red Jewel L99
Engine-fuel-cutoff,DFCO
Look at the RPM limits section.
Motion427 is offline   Reply With Quote
Old 06-16-2013, 10:18 PM   #397
Pro Stock John
Writer
Thanks... and WOT timing advance?
PROJECT HEAVY CHEVY
Old 06-16-2013, 10:27 PM   #398
xjer22x
xjer22x's Avatar
Look at you go! Bring that with next time for sure.
Old 06-16-2013, 10:31 PM   #399
Rhino79
Rhino79's Avatar
Spark> High and Low octane tables. Then there are modifier tables under spark for IAT correction, ECT correction, and AFR Correction. AFR will likely be 0'd out,
Old 06-17-2013, 08:09 AM   #400
Motion427
Exactly what Rhino posted.
Most tuners zero the "Spark correction AFR Correction GAS" table and then adjust the low and hi octane tables to the desired timing.
When stock the spark correction afr correction gas add more timing depends on where the AFR is at at WOT.
Example if the ECM commands 1.20 AFR,which is 12.23AFR
On a stock tune(mine anyways),it starts adding timing at 3600 which was (+0.5)all the way up to +5 degrees of timing at 6000RPM.
This table is only activated when your in WOT.
You can add 1-2 degrees and try it,depends on the fuel grade that you have in the car,some like it some hate it.Especially on a stock cam.
The moderator might not like us too much. I thought this was racing section. lol....
Old 06-17-2013, 09:13 AM   #401
Pro Stock John
Writer
Finally found a spot to do a rip, onramp to 90/94... TCS off, 1-2 shift was decent looked low on the tach like 5 grand, (factory tach slow? they used to be for the 4th gens)
Jerry I can't go Thur, but I can go Tues and Wed. Tues looks cooler but the track is not as good, what do you think? Going out again?
Thanks guys for the tune help. What is typical max WOT timing stock?
Back to racing, ran the NT05's at 18 last time, does anyone run them lower?
PROJECT HEAVY CHEVY
Old 06-17-2013, 09:20 AM   #402
xjer22x
xjer22x's Avatar
I was thinking of heading up tomorrow. With a little moreh heat on our tires I think we might be good. I will let you know early tomorrow if I can go.
Nice to hear its shifting better. Bring the HPT with you so we can adjust if needed
Old 06-17-2013, 09:29 AM   #403
Pro Stock John
Writer
Sounds good I'm interested for sure. I think I have jury duty tomorrow but that should make it easier to get up there earlier.
PROJECT HEAVY CHEVY
Old 06-17-2013, 09:36 AM   #404
xjer22x
xjer22x's Avatar
Ick, that's never fun. I was thinking of trying to get there earlier to let the car cool off a bit more. I will be keeping an eye on DA too.
Old 06-17-2013, 10:13 AM   #405
Pro Stock John
Writer
Clean and ready for battle:
PROJECT HEAVY CHEVY
Old 06-17-2013, 10:51 AM   #406
xjer22x
xjer22x's Avatar
HaHa... still riding on the radials. Love it!
