AAC Style
Old 04-24-2013, 06:04 PM   #1
11Huggerwhite
11Huggerwhite's Avatar
Drives: 2013 Camaro SS supercharged
Race gas
Finally ran a tank of race gas, and the car runs completely different. It runs smoother and can tell a power differences also. Who else runs race gas in the cars?
11Huggerwhite is offline
Old 04-24-2013, 06:50 PM   #2
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
Hope you don't need to pass a smog check, race gas will kill the cats.
upflying is offline
Old 04-24-2013, 08:38 PM   #3
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
The cost alone isn't worth it or actually legal to use on the street since most of it has lead in it. You don't list any mods but a stock SS with a supercharger certainly doesn't warrant race fuel and should be tuned for it as well.
I doubt the OP has cats to worry about anyways since he shows being supercharged. Florida does not have any smog or inspections.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline
Old 04-24-2013, 08:48 PM   #4
11Huggerwhite
The car has no cats headers cam supercharger etc it makes 593whp right now till the pulley change next week.
Old 04-24-2013, 08:51 PM   #5
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
At the very least i'd get it hooked up to a wideband and see what's going on when running it. Don't want to cause any issues with the timing and boost levels on race fuel.
Old 04-24-2013, 08:58 PM   #6
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
this.
And like he said you need to tune for race gas, then of course you are stuck with it. I'm assuming you are using race gas that is designed for a supercharged engine as well.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline
Old 04-25-2013, 03:08 AM   #7
slomaro3.4
slomaro3.4's Avatar
Drives: SS/RS L99 Crew
Always run on the gas your car is tuned for. The placebo effect is not good enough. Yeah you can advance the timing but you need that tune, and if its an A6 you need a vvt tune or your hp curve will be either exactly the same or a little kinky.
#YOLO
slomaro3.4 is offline
Old 04-25-2013, 03:46 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you can tell a nice power gain, your engine has some knock in it on the 93/91 tune or you had some crappy gas.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
axis is offline
Old 04-25-2013, 07:29 AM   #9
2SS 2011
2SS 2011's Avatar
Drives: 2011 Camaro 2SS/RS M6 Black
The difference is purley in your mind.. The compression ratio on the engine is set to run on regular gas.. anything else is a waste of money unless it's tuned.. trust me.. Been there done that
2SS 2011 is offline
Old 04-25-2013, 07:29 AM   #10
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
In car properly tuned for pump gas, race gas will make it run worse.
Iron Lung Jimmy is offline
Old 04-25-2013, 08:44 AM   #11
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
This story involves a mild performance carbureted engine, but the concept is the same as with injected engines:
http://www.popularhotrodding.com/tec...pump_race_gas/
To make it short, basically a waste of money unless you have the compression to require it!
gajagfan is offline
Old 04-25-2013, 10:07 AM   #12
onechuck
Onechuck
onechuck's Avatar
Drives: 2010 Camaro IBM 2SS\RS SC & Cammed
I run 5 gallons off race fuel to a full tank of super unleaded every time I fill up. The car runs flawlessly. It is so responsive to this. Also my exhaust tips have no black crud on them either.
onechuck is offline
Old 04-25-2013, 07:33 PM   #13
two_wheel_mayhem
Please don't tell me you buy that stuff they sell at the gas station?
What you need if you really want performance is some VP100 or some VP Motorsport109. These are oxygenated unleaded race fuels. They will increase horsepower on your low compression or supercharged engine.
That stuff at the gas station is for normally aspirated high compression engines and not to boost power it's because they need it. Also rumoured to damage oxygen sensors, waste of your money ,loss of your horsepower. The higher the octane the slower the fuel burns.
Old 04-25-2013, 11:08 PM   #14
SPCBA
Drives: pleather and Chiclets
"race" gas is leaded....bad juju
SPCBA is offline
