GM Parts House
Old 05-07-2013, 05:02 PM   #57
429
Drives: 2010 camaro ss
Welds shipped today.
429 is offline   Reply With Quote
Old 05-07-2013, 07:08 PM   #58
Bad Dad
Bad Dad's Avatar
Drives: 2010 2SS/RS , 2011 C6 Base Corvette
great
Bad Dad is offline   Reply With Quote
Old 05-08-2013, 09:41 AM   #59
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
So I'm wondering what the difference/benefit of those lower control arms are vs the TCA029 $599 ones? Aside from allowing 15" rims....
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 05-08-2013, 09:51 AM   #60
429
They wont work with a stock style shock, so its kind of a moot question. They're cheaper because they're MUCH simpler, but like I said, wont work with a stock style shock.
Old 05-09-2013, 01:16 PM   #61
429
welds came today. one day short of a month after i ordered - be aware they are built to order and theres a 3-4 week lead time on the wheels.
Old 05-09-2013, 04:54 PM   #62
429
48.8 pounds per wheel/tire.
Compare to 54.2 pounds for the 17" rt-s and 295/45/17 et street radial... saves 11 pounds (5.4 each) rotating mass in addition to the brake/suspension package weight savings.
Old 05-09-2013, 06:55 PM   #63
Bad Dad
Bad Dad's Avatar
SAWEEEEEET lets see em on 429
Old 05-09-2013, 06:58 PM   #64
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
That is awesome, can't wait to see your final weigh in. The wheels look great.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline   Reply With Quote
Old 05-10-2013, 03:30 PM   #65
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Looking good 429, anxious to see how those new 275 MT's work for you. We have them on our Mustang shop car and they are amazingly sticky! I am kind of wondering if we might actually run some better short times with them than we are with the slicks!
BMR guy is offline   Reply With Quote
Old 05-11-2013, 09:56 AM   #66
L99CAMA2011
L99CAMA2011's Avatar
Originally Posted by BMR guy View Post
BMR Suspension
Drag Race Suspension Package for the 2010-2013 Camaro
Reduce un-sprung weight, solidify the rear suspension, and increase drag strip launch consistency in your Fifth Gen Camaro with a Drag Race Suspension Package from BMR Suspension. Manufactured from lightweight chrome-moly and utilizing adjustable rod ends, these components are designed with the drag racer in mind. The BMR Drag Race Suspension Package (DRP007) includes adjustable chrome-moly lower control arms, adjustable trailing arms, a coil-over conversion kit, and a pair of Strange double adjustable coil-overs with Hyperco springs. When used in conjunction with the BMR 15 Wheel Conversion Package (BCP001), you can expect the weight of your Camaro to drop 74 pounds. This package also allows the racer to use 15 Weld Racing rims when combined with part number BCP001. Installation time is 4-5 hours.
To preview all of BMRs high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Avenue, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
BMR are these rear shocks for road course use as well or just drag. Also can they work with 650lbs rear springs as well or just the 500lbs.
Old 05-11-2013, 10:06 AM   #67
L99CAMA2011
Cutting these to fit the spring pocket was a little pain, but only took a couple minutes with the die grinder and a football burr. Hate the metal shards everywhere, damn things always get stuck in my shoes or hands. Onto the other side, got to mityvac the brakes, and then will go out for a ride (if ride height is close enough)
Oh, and BMR you should mark the shock mounts L and R, lol. Had to look at them for 10 minutes like a dumbass before I figured which was which.
Rear shocks don't need left to right markings only fronts Macpherson struts.
Old 05-11-2013, 10:10 AM   #68
429
i didnt say shocks, i said shock mounts. they are different.
Old 05-11-2013, 10:45 AM   #69
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Beware of burnouts! These tires are sticky, but soft. We boiled through a set in 6 races, our goodyear eagles get us 30. Doing the same burnout. We called MT to bitch and they told us we were just supposed to burp the throttle, a couple spins to clean them off, no need to heat them. They hooked real good for sure but we went back to Goodyear, for the smoke!
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 05-11-2013, 10:50 AM   #70
429
