Jason 98 TA
Old 04-30-2013, 08:30 AM   #15
Merc
In The Circle
Merc's Avatar
Originally Posted by B-rad View Post
I have been waiting to do this mod. Is it plug and play or is it a little more complicated than that?
If you use the Lingenfelter box it is plug and play and pretty straight forward. However disconnecting the plug from the clutch position sensor to install the Lingefelter tap harness is not. The harness plug requires that you pull out a grey safety lock pin first and then use a pick to unlock a second lock. You also have to go cat delete or you will bang out the cat's from repeated use of the 2-step.
Old 04-30-2013, 01:06 PM   #16
B-rad
Yellow Stealth
Drives: 2010 2SS Camaro, 1999 WS6 Trans Am
Glad to hear lingenfelter figured out how to make this install a little easier. I didn't realize I would have to do a cat delete though. I'm not sure I want to go that route.
B-rad is online now   Reply With Quote
Old 04-30-2013, 02:45 PM   #17
Merc
In The Circle
Merc's Avatar
Not sure how much you have to use it before you would bang the cat's out. I just got the cat delete sections from ARH. They were cheap and easy to change out and Pumpkin sounds great without them.
Old 05-05-2013, 11:03 AM   #18
Merc
In The Circle
Merc's Avatar
Epic Fail
Although we got Pumpkin to run the fastest time ever by 3/10's the MSD 2-step was an epic fail. The first pass out of the box was a 13.00, what the f@#k. Tried again same thing and Pumpkin just did not sound right by my friends observations. We tried putting the old tune back in, no difference. So we disconnected the 2-step from the ignition system and Pumpkin instantly went back to a 12.40 car. Put the JRE tune back in and got after it and turned a 12.08.
Some how, some way the MSD 2-step screws with the ignition signal.
I'm thinking that baby is headed to the river.
Old 05-05-2013, 11:45 PM   #19
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
Thats all bad Merc. I'm curious now to see how Robs 2 Step behaves at the track.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 05-06-2013, 08:21 AM   #20
Merc
In The Circle
Merc's Avatar
Bryan
Planning on talking to MSD tech dept, maybe I got a bad one.
Old 05-06-2013, 04:04 PM   #21
Merc
In The Circle
Merc's Avatar
Talked with MSD this morning and they were no help. So I gave Jason at Lingenfelter a call about getting one of there daul stage 2-steps, but he wanted to try and solve the MSD 2-step first. Apparently routing of the wiring and placement of the box can be an issue as they my pick-up RF signals and partially trigger the 2-step. Got to take a bunch of photo's of wire routing and box placement to send off to Jason for a look see.
Old 05-06-2013, 04:10 PM   #22
Chevrolade
Drives: 2010 2SS/RS
You auto or Manual?thought of putting one in my a6 but seems like everyone has better results off idle
Chevrolade is offline   Reply With Quote
Old 05-06-2013, 08:43 PM   #23
Merc
In The Circle
Merc's Avatar
Manual. 2-step will only work on a manual.
Old 05-07-2013, 12:24 AM   #24
Robd
Robs SS
Robd's Avatar
Drives: 2011 camaro ss synergy
Mine seems to be working good used it a good ten times mines mounted on side of air box and wires are run behind front pulley from Side to side did you use the ground activation wire versus the positive activation wire wonder if that has anything to do with it acting up ? I used the ground one so I didn't have a hot wire running through firewall from clutch micro switch
[COLOR=lime]my kinda going green POWER 605 RWHP powered by maggie chrome tsv 2300 supercharger,ar long tube headers high flow cats b and b exhaust ,roto fab intake ,lingenfelter cam , upgraded sc reservoir ,Comp cams
performance valve springs, Comp cams Titanium retainers,Heavy duty valve locks,MSD ignition wires, Kool Sox heat resistant heat sleeves , Larger fuel injectors, high flow fuel rails,American racing rims ,hurst short throw shifter,led footwell and grille lighting,pfadt suspension upgrades
Robd is offline   Reply With Quote
Old 05-07-2013, 09:00 AM   #25
Merc
In The Circle
Merc's Avatar
I suspect I might have to move the box, which maybe too close to the plug wires. I used the ground activation as well. Have you run it down the track yet?
Old 05-07-2013, 11:06 AM   #26
spd2612
Drives: Black SS2/RS LS3
I am getting ready to install one of these has anyone got any pics of your home made micro switch bracket and where you are mounting it.
What are you setting it at? I was thinking between 2500 and 3000 rpm.
spd2612 is offline   Reply With Quote
Old 05-07-2013, 12:44 PM   #27
Merc
In The Circle
Merc's Avatar
I generally launch Pumpkin around 4500. I'm going to use a Lingenfelter CTAP-01 box rather then a micro switch, much easier to adjust. Plan to start @ 95% setting on box, which would be 5% of clutch pedal travel off the the floor.
Old 05-07-2013, 12:50 PM   #28
spd2612
Are you running the stock differential
Is the clutch switch mounted at the top of your pedal or the bottom, I havent really looked under the dash yet
