Cold Air Inductions
Old 04-25-2013, 07:22 PM   #1
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2013 Crystal Red Metallic 2SS RS
Paint help on engine cover URGENT
Okay, so I used a clear adhesion promoter, forgot if I coated the whole engine cover . I taped off the black areas, painted 4-6 coats of CRT. Removed the tape, it left a lot of sticky behind, used alcohol, paint thinner, then washed it.
Question 1, still might be a little tacky, anything else I can try? Or will the adhesion promoter seal it?
Question 2, is it okay to re coat, including the fresh CRT paint, with the adhesion promoter before I clearcoat? And do I assume correctly that I need a 1000 grit sand between clears?
Thanks a ton for your help.
Jim
2013 CRT 2SS RS – Heritage Grille, CAI, ZL1 Style Splitter, Chrome OEM Wheels.
CamaroJim56 is offline   Reply With Quote
