HeadlightArmor
Old 04-25-2013, 11:25 PM   #1
2SS 2011
2SS 2011's Avatar
Drives: 2011 Camaro 2SS/RS M6 Black
Showstopper accessories plenum cover
Brand new for 2010-up camaro LS3 engines
$120 shipped
brand new in bubble wrap with protective plastic on it..
caseclosed27@aol.com
Paypal accepted
2SS 2011 is offline   Reply With Quote
Old 04-26-2013, 04:03 PM   #2
Infern0
Bring It
Infern0's Avatar
Drives: '17 Camaro ZL1 (M6)
Is this for the yellow part or the surrounding part?
2017 Camaro ZL1 M6 - Everything but the sunroof - New Daily Driver! Commuting has never been so fun.
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 04-26-2013, 04:38 PM   #3
2SS 2011
2SS 2011's Avatar
Surrounding part..
I do have a C5 member who PM'd me about this first so If he goes through with it then it's only fair it goes to him..
If he doesn't you are def 2nd in line..
Just want to be fair and cool
Old 04-27-2013, 09:46 AM   #4
5th_GEN_SS
Junkie
5th_GEN_SS's Avatar
Drives: SIM 2SS/RS M6
Think I am backing out, all yours
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
5th_GEN_SS is offline   Reply With Quote
Old 04-27-2013, 10:19 AM   #5
2SS 2011
2SS 2011's Avatar
5th Gen.. No prob man.. !
Old 04-28-2013, 05:15 PM   #6
2SS 2011
2SS 2011's Avatar
bump
Old 04-28-2013, 05:47 PM   #7
Pharmaro
Pharmaro's Avatar
Drives: 2011 CGM 2SS/RS
Just curious if you've run across any pics of this installed on anyone else's car. Kind of hard to tell from their stock pic how it would look.
Pharmaro is offline   Reply With Quote
Old 04-29-2013, 09:31 AM   #8
2SS 2011
2SS 2011's Avatar
I think Laditee has it on her car.. im going to try to find a pic and post it
Old 04-29-2013, 09:37 AM   #9
2SS 2011
2SS 2011's Avatar
here is a better pic
Old 04-29-2013, 09:31 PM   #10
Pharmaro
Pharmaro's Avatar
Thanks! I have the Holley big block coil pack covers and this looks like it may be incompatible :(
Old 04-29-2013, 09:40 PM   #11
2SS 2011
2SS 2011's Avatar
actually thats the combo I had thatI was gonna put on..Just decided to go a diff route The part thats shaded is supposed to overlap the plenum cover making it look like the cover is too wide.. Ill take a pic of the actual plenum cover to show you if your still interested
here is a pic with the Holly valve covers on .. and here is a pic of the plenum cover wich only goes as far as the fuel rails
it basically will sit flush on the plenum and just meet the valve covers.. Thats how I measured it when i bought the stuff.. the screw hole on the top of the right rail is where the hole on the plenum cover is to bolt into place so it doesn't go farther than the end of that bolt hole.. giving about a 1/4 inch of clearance
Old 04-29-2013, 09:50 PM   #12
Pharmaro
Pharmaro's Avatar
Hmmm. That is the mess I'm trying to hide
Old 04-29-2013, 09:51 PM   #13
2SS 2011
2SS 2011's Avatar
yes and the plenum cover does just that...it goes right over the plenum and hides the fuel rails.. if anything it will sit flush with the valve covers
you can see in the pic the 4 holes for the bolts coming off the fuel rails 2 in the back and two in the front on each side.. I just measures the length from the bolt holes from the pic and on the plenum cover.. it's only like an 1/8th of an inch or so.. so like I said it should sit flush with the covers. The pic of the plenum doesn't show how it is wide in the front until the back of the power steering pump then it gets thin.. (the stock pic gives the impression its that wide all the way to the back making one think it wont fit.. here is a pic i just took.. see how the piece in front comes forward to cover the throttle body
Old 04-29-2013, 10:27 PM   #14
Pharmaro
Pharmaro's Avatar
My only remaining concern is that my coil pack covers don't sit as far down as yours do. Nice engine bay by the way. Haven't seen the battery and relays/heat sink relocated like that.
