Solo Performance
Old 04-27-2013, 12:34 PM   #15
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Originally Posted by dcoates18481 View Post
My 2010 was limited to 155.
You have to tune it out. Now it goes faster than that
The coupes have no limiter from the factory, and will go plenty fast.
Old 04-27-2013, 12:53 PM   #16
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 13 ZL1, 15 Scat Pack,& 15 Silverado
wait wait... So the verts don't have PTM and their limted to 155mph? That's messed up lol.. I took mine up to 170 when she was stock.. She had a lot more in her!
2013 M6 ZL1.. Mods- Roto-Fab CF Intake, Ported and Polish LS7 TB and Snout, 2.55" Upper Pulley, 100mm Idler Pulley, Solid Isolator, Afco Heat Exchanger with fans, ID850 fuel injectors, SW 2" LT Headers With High Flow Cats, and CMS 91 Octane tune.. 579.8rwhp and 537.4rwtq
TripleBlkZL1 is offline   Reply With Quote
Old 04-27-2013, 01:36 PM   #17
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2012 CTS-V coupe
187mph in my last car was deadly quiet and tracked completely straight.........I just ran out of man marbles. At nearly 300' per second you don't have a lot of room for error. Back on topic though, and seriously a concern, at what speed with the convertible top just peel itself away from the car or possibly be damaged in some way?
REDLINE
2016 Corvette Z06 3LZ
Callaway SC757
"I lived my life by one motto.......mottos are for losers" cvp33
cvp33 is offline   Reply With Quote
Old 04-27-2013, 03:28 PM   #18
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Lot of threads on this topic, but actually yes the coupes (and verts) are limited to 155, barring a tune. Zl1 coupes are not. The main reason is above 155 the front end begins to lift, they changed that with the zl1 coupe hence no longer speed limited.
http://www.camaro5.com/forums/showthread.php?t=169208
http://www.camaro5.com/forums/showthread.php?t=160452
https://www.google.com/search?q=cama...+speed+limited
BigBlock69RS is offline   Reply With Quote
Old 04-27-2013, 03:55 PM   #19
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Originally Posted by TripleBlkZL1 View Post
Negative.. I hit 170mph stock
on a ss coupe or your ZL1?
Trentin24 is offline   Reply With Quote
Old 04-27-2013, 04:00 PM   #20
alex70olds
alex70olds's Avatar
Drives: 2012 ZL1 #141
If he said stock, must be the ZL1.
alex70olds is offline   Reply With Quote
Old 04-27-2013, 04:02 PM   #21
TripleBlkZL1
Sorry I didn't read his post right. I thought he wrote that the couple ZL1's were limited
Old 04-27-2013, 04:09 PM   #22
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
That's what I thought haha. no worries
Old 04-27-2013, 04:42 PM   #23
TripleBlkZL1
I had a 2010 SS coupe and was devastated when I found out it was limited
Old 04-27-2013, 05:57 PM   #24
DarkneZZ
DarkneZZ's Avatar
Drives: '13 Camaro 2LT/RS
2013 2LT/RS has a 145mph limiter. Tested.
DarkneZZ is offline   Reply With Quote
Old 04-27-2013, 06:37 PM   #25
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
2010 1LT has a 118 limiter. Tested
Due to the tires
Old 04-27-2013, 06:49 PM   #26
SlingShot
SlingShot's Avatar
Seeing this is the ZL1 area, and the topic was ZL1 Verts, My statement needed no correction about the coupes had no limiter from the factory.
Old 04-27-2013, 06:55 PM   #27
45thCAMARO 2SS/RS
xquest91x
45thCAMARO 2SS/RS's Avatar
Drives: 2012 45th Anniversary 2SS/RS
Who ever is saying that only verts are limited is wrong, I have a 2012 SS coupe and I hit 155mph n got the "speed limited" to 155 mph but yes u can get a tune to remove the speed governor. Now 155mph wasn't fast enough for me so I tuned it n so far I've hit 168mph but I was running out of road so I had to start slowing down after that.Now on the ZL1 yes verts are limited and coupes are not, just adding my 2cents
45thCAMARO 2SS/RS is offline   Reply With Quote
Old 04-27-2013, 07:17 PM   #28
SlingShot
SlingShot's Avatar
WE ARE TALKING ABOUT ZL1 VERTS, AND ZL1 COUPES ONLY. You guys keep bringing up stuff about the SS, that should be done in the SS section and not here.
