third_shift studios
Old 04-27-2013, 11:19 AM   #1
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
LCA question
Just did a bunch of suspension mods, and at some point this summer or fall, I want to do coilovers and probably LCA's for the hell of it while I have the car apart.
some LCA's are made shorter to accommodate for camber correction on a lowered car.. currently, In addition to sways/bushing upgrades, I have BMR non adjustable toe rods and trailing arms.
This is taken from BMR's site in reference to their non adjustable LCA:
Due to shortened length of these control arms, adjustable toe rods are necesarry when using this product.
Is this true? If this is the case, I would imagine the other options such as Spohn, etc would have the same issue. Does anyone have any first hand experience with this? I really dont feel like removing and selling the toe rods I just put on, so I want to make sure I buy a LCA that works
Thanks, Joe
BronxxBombers213 is offline   Reply With Quote
Old 04-27-2013, 11:27 AM   #2
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I can't really answer your question but I installed my LCA's and adjustable toe rods when I put my Gforce 9 inch in and now for some reason my axles are hitting my upper control arm and have worn a groove in it!! I have KWV1 coilovers on it so now I'm trying to figure out why my axles are rubbing my upper control arm.
MODS:
Old 06-17-2013, 12:25 AM   #3
BronxxBombers213
still curious
Old 06-17-2013, 06:49 AM   #4
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
yes its true
jeremywes is offline   Reply With Quote
Old 06-17-2013, 08:48 AM   #5
BMR Sales
BMR Sales's Avatar
Drives: Race Car
If you plan on running our non-adjustable lower control arms (TCA028) you will definitely need andjustable toe rods to be able to get the alignment back into spec because the lower control arms are shorter than the factory arm. If you run our adjustable lower control arms (TCA029) you don't have to run adjustable toe rods if the car is stock ride height or close to it, now if you are going to lower the car a good bit you will definitely still want to run the adjustable lower control arms so you can get the desired alignment specs.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
BMR Sales is online now   Reply With Quote
Old 06-24-2013, 03:56 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS and Twin Turbo'd SRT8
How about a set of LCAs for the new suspension to take advantage of the better sway bar design and sizes???
Old 06-24-2013, 03:34 PM   #7
BMR Sales
BMR Sales's Avatar
Drives: Race Car
It is something we are definitely working on and should hopefully have ready sooner than later. I keep on pushing my R&D guys on this because we have been getting so many request about this kind of thing lately. I will sit down with them and see where we stand with this.
T.C. Davis
813-986-9302
Old 06-24-2013, 04:53 PM   #8
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
With the non-adjustable BMR toe rods and trailing arms that you already have..I have them also,
I would just go with GM's revised 2012 lower control arms and 1LE or ZL1 sway bars.They can't be beat and will out perform any bars that mount inboard like the 10's and 11's.
That setup will align perfectly on a lowered car plus the LCA are only about $35.00 a piece direct from GM.
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
