Gen5DIY
Old 04-28-2013, 11:05 PM   #15
Unreal
Drives: 2006 Z06
I think the over 500ft/lbs is a typo. LS7s make ~440 torque. No way they got 60+tq out of it.
Nick
Corvette Z06 -1200ish rwhp
Old 04-28-2013, 11:10 PM   #16
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
It does have adjustable dampers...
Old 04-28-2013, 11:30 PM   #17
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
That's the 2nd time I have seen it so I guess we will have to wait until they release the final numbers.
Bhobbs is online now   Reply With Quote
Old 04-29-2013, 12:22 AM   #18
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Originally Posted by The Stig View Post
Is it only certain races its not allowed or is it by class?
That's for SCCA classes except for this:
9.3.2. ACTIVE SUSPENSIONS AND TRACTION CONTROL SYSTEMS Active suspensions and traction control systems, as installed by the automobile manufacturer and unmodified, are allowed only in Touring.
9.3.44. SUSPENSION AND STEERING Suspension and steering shall be of suitable design and in good working order. Four wheel steering is prohibited. Unless specifically permitted, non-metallic suspension control arms, locating links, toe/steering links and pushrods are prohibited.
9.1.1. FORMULA CATEGORY CLASSES Formula Atlantic (FA) Formula 1000 (FB) Formula Continental (FC) Formula Enterprises (FE) Formula Vee (FV) Formula F (FF) Formula 500 (F5) Formula Mazda (FM) Formula S (FS) Regional Class Formula First (FST) Regional Class Formula 600 (F6) Regional Class 9.1.1 continues in the Formula Category Rules.
9.1.2. GRAND TOURING CATEGORY CLASSES GT-1 (GT1) GT-2 (GT2) GT-3 (GT3) GT-Lite (GTL) 9.1.2 continues in the GT Category Rules.
9.1.3. IMPROVED TOURING CATEGORY CLASSES (REGIONAL CLASSES) R (ITR) S (ITS) A (ITA) B (ITB) C (ITC) 9.1.3 continues in the Improved Touring Category Rules.
9.1.4. SUPER TOURING CATEGORY CLASSES STU (STU) STL (STL) 9.1.4 continues in the Super Touring Category Rules.
9.1.5. PRODUCTION CATEGORY CLASSES E Production (EP) F Production (FP) H Production (HP) 9.1.5 continues in the Production Category Rules. 9.1.6. SEDAN CATEGORY American Sedan (AS)
9.1.6 continues in the American Sedan Category Rules.
9.1.7. SPEC MIATA CLASS Spec Miata (SM) 9.1.7 continues in the Spec Miata Class Rules.
9.1.8. SPORTS RACING CATEGORY CLASSES A Sports Racing (ASR) Regional Class C Sports Racing (CSR) D Sports Racing (DSR) Sports 2000 (S2) Spec Racer Ford (SRF)
9.1.8 continues in the Sports Racing Category Rules.
9.1.9. TOURING CATEGORY CLASSES: Touring 1 (T1) Touring 2 (T2) Touring 3 (T3) Touring 4 (T4) 9.1.9 continues in the Touring Category Rules.
9.1.10. B-SPEC CATEGORY CLASSES B-Spec (B-Spec) 9.1.10 continues in the B-SPEC Category Rules.
9.1.11. SPEC MX-5 CLASS Spec MX-5 (SM5) Regional Class 9.1.11 continues in the Spec MX-5 Class Rules.
9.1.12. CARS RUN IN THE PROPER CLASS A. All cars shall race in their respective classes. B. Cars should not be run in classes and/or categories for which they were not designed or intended. The Chief Steward must approve the proposed classification. He will not approve if the car is so dissimilar or the car/driver combination otherwise unsuitable that it is a hazard or impediment to fair competition among the other cars in the class and race group.
I believe the Corvette participates in the Grand Touring class. Not sure which one though.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 04-29-2013, 01:04 AM   #19
The Patch
The Patch's Avatar
Drives: 1969 Pro-Touring 2013 ZL1
I don't buy the rough ride idea. I guess everything is relative. Not doubt my '69 Pro-touring is a rougher ride than the '14 Z28. But, it's not like the 69 is an uncomfortable ride. Maybe people are getting soft these days. I'd buy a Z28 in a heartbeat if hadn't just purchased a ZL1.
The Patch is offline   Reply With Quote
Old 04-29-2013, 04:16 AM   #20
sho928
Drives: Porsche 928 S4, Mustang GT vert
Correct, however with 12.5:1 compression, direct injection and cam profile similar to the C7 (450-hp, 450-tq estimated out of 6.2 L) it would be possible (particularly with long tube headers and 3" exhaust) at the flywheel.
No mention of this for 2014 however but for a 3,800-lb track car 500 lb-ft of torque is a useful target to have since that is what allows the ZL1 to have better lap times (most tracks) than the GT500 by using it's superior traction to lay down the torque to generate higher corner exist speeds.
http://www.chevroletperformance.com/...2397&engCat=ls
"the LS7 uses a 7.0-liter aluminum dry-sump block, CNC-ported cylinder heads, and titanium rods and valves to pump out 505 hp and 470 lb.-ft. of torque."
30 lb-ft could be gained with CAI, low restriction exhaust and tuning
sho928 is offline   Reply With Quote
Old 04-29-2013, 09:05 AM   #21
madmax13
Drives: '13 2SS/RS/1LE/NPP
The shocks are 4 way adjustable. Tuned for both high speeds and low speeds. So it is entirely possible that it will ride decently on the street....
but it is a racecar so who cares!
madmax13 is offline   Reply With Quote
Old 04-29-2013, 10:47 AM   #22
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Yes 470 TQ! I believe the intake and exhaust have been modified for the Z/28, so the comment of over 500 is possible.
2cnd chance is offline   Reply With Quote
Old 04-29-2013, 11:12 AM   #23
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Just for fun...what performance difference would A/C make?....Perhaps as it is an option, just wondering if it would be designed so you could by-pass with a different belt or whatever if desired...
....Some may want A/C for street use, but not want it for their track days and have a power loss...???
90503 is offline   Reply With Quote
Old 04-29-2013, 11:18 AM   #24
2cnd chance
If it's off doesn't it freewheel? It will add some weight to the nose though. I can't imagine you'd see much difference in lap times with it off.
Old 04-29-2013, 11:23 AM   #25
90503
90503's Avatar
...That's what I don't know...thought even if it was there it would be a "drag"...lol...even if off....
Old 04-29-2013, 12:22 PM   #26
Synner
Drives: not stock
People are whining it doesn't have heated seats or a nice stereo. Lots of people just don't get it and never will.
Old 04-29-2013, 12:37 PM   #27
The Stig
knows 2 facts about ducks
The Stig's Avatar
It's not so much the loss of power - but how much extra weight adding A/C would be.
Click to view my build thread
