HeadlightArmor
Old 04-28-2013, 08:53 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
header install on an auto vs 6 spd ZL1 comments
I have had the opportunity to install headers on my own A6 ZL1 and Smitty's M6 2013 ZL1. I have not finished Smitty's car yet but wow...there is a bunch of room in an M6 car vs an A6. The rear 02 connectors are so easy to reach in the M6 as well. I'm just commenting on the relative ease of an M6 install vs an A6. If you have an M6 car and have some mechanical skill, don't be scared to tackle this one. A6 cars are not bad but some interferences may be present that do not exist on the M6 like the differential cooler lines that run on the driver's side tunnel which nearly blocked my front 02 sensor on the Texas speed headers.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 04-29-2013, 07:56 AM   #2
toyosuprablue
Drives: 2013 ZL1 Black M6
Kooks were an easy install on my M6.
Note: Clearance on the steering knuckle is one concern I've seen mentioned but I forget what brand LT header that was for.
toyosuprablue is offline   Reply With Quote
Old 04-29-2013, 08:08 AM   #3
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
I disconnected my intermediate steering shaft to put my ARH LTs on. It's probably these.
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 04-29-2013, 08:35 AM   #4
npd337
Drives: 2013 Ash Zl1
Was that for a zl1 with the arh headers? Was thinking of doing the install of those myself. If there is going to be clearance issues with them I'll try and find something with less of an issue.
npd337 is offline   Reply With Quote
Old 04-29-2013, 04:31 PM   #5
Stephen12ZL1
Drives: '17 ZL1 A10
The steering universal joint has a dust boot that had to be removed on my car with the Texas Speed headers. I haven't checked the Stainless Power headers with Smitty's car yet to see if I have to cut that off. It's no biggie to cut off...just thin rubber and the belly pan protects that area from road grit.
Old 04-29-2013, 09:04 PM   #6
Stephen12ZL1
Drives: '17 ZL1 A10
steering u joint dust boot must be removed with Stainless Power also. Stainless Power connection pipes much easier to fit and overall better than Texas Speed. Spark plug clearance is worse with the Stainless Power as the socket drags on the thicker flange and makes the spark plug boot fit very close to the flange with the stock plug wires. Best bet is to get a set of MSD wires to get the best clearance. Overall I give Texas Speed an 8 out of 10 and Stainless Power 9.5 out of 10.
