Old 04-29-2013, 12:36 PM   #1
321 CYA
Drives: 2013 Rally Yellow Camaro 2SS/RS
1LE wheel offset?
What is the 1LE wheel off set? and they are both 20x10 correct?
Thanks for the help. Trying to get a square setup on my SS.
Thanks
321 CYA is offline   Reply With Quote
Old 04-29-2013, 12:53 PM   #2
Phdpsy
Phdpsy's Avatar
Drives: SW 2013 1LE
1LE are 20x10 And 20x11 exactly as ZL1...just with 285s all around. If you want a true square set up, try something like TSW Nurburging 20x10 et35. Can run 285s (and some 295s) all around and rotate as needed for better tire life. Can't rotate the 1LE/ZL1 set ups.
Phdpsy is offline   Reply With Quote
Old 04-29-2013, 12:57 PM   #3
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Keep in mind the 1LE rear wheels wont fit the on the front. They contact the struts.
You could get square with 4 1LE fronts.
Southern Comfort is offline   Reply With Quote
Old 04-29-2013, 01:08 PM   #4
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Not sure of the offset, but the front wheels are 10" and the rears are 11". I also know that the 11" wheel does not fit on the front. The tires are the same on all 4 wheels (285/35/20's).
gajagfan is offline   Reply With Quote
Old 04-29-2013, 01:13 PM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
** EDIT +23 up front and +43 in the rear.
Best regards,
Tyler
888-308-6007
Old 04-29-2013, 01:22 PM   #6
321 CYA
Thanks everyone this is the info I have been looking for!
Thanks again!
Old 04-29-2013, 01:25 PM   #7
321 CYA
Tyler what it the web page that has this offset comparison on?
Old 04-29-2013, 01:30 PM   #8
JDP Sales
JDP Sales's Avatar
I found that on this site in a search, so I am not sure.
Best regards,
Tyler
888-308-6007
Old 04-29-2013, 01:32 PM   #9
321 CYA
Best regards,
Tyler
888-308-6007
Thanks I found it!
Old 04-29-2013, 01:35 PM   #10
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Actually the ZL-1 and 1LE offsets are as follows:
20x10 fronts offset +23mm ( this will clear OEM struts with a 285/35/20 tire ) If you have some coil overs you can move the wheel/tire assembly inboard a bit with more positive offset such as +30mm
20x11 rears offset +43mm
GM picked these sizes and offsets so that the front and rear track would be the same on the ZL-1 and 1LE.
If you put a front 20x10 with +23mm offset ZL-1/1LE wheel on the rear the wheel will stick out .3" more than the 20x11 +43mm offset wheel on the rear. Pretty aggressive.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 04-29-2013, 01:49 PM   #11
NinoSS
Drives: 2SS/RS CGM LS3
Ed M.
He is correct... See pics (my wheels) below...
Front
Rear
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 04-29-2013, 01:52 PM   #12
NinoSS
I have pics of them on a digital scale too...
Old 04-29-2013, 02:29 PM   #13
JDP Sales
JDP Sales's Avatar
Ed M.
Thank you for the correction! Good to know.
Best regards,
Tyler
888-308-6007
Old 06-17-2013, 09:11 PM   #14
GT09OK
Drives: 09 G8GT
Will a 19x9.5 backspacing 42mm fit on a 2013 1le camaro and clear brakes and all?
GT09OK is offline   Reply With Quote
