Old 06-24-2009, 11:41 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
L99 transmission cooler install
another late night, just got the B&M "Hi-Tek" cooler mounted and lines installed, 13"x9" with its own thermal switch and 9" cooling fan
just test fitted the front bumber cover back on and everything fits fine
Old 06-24-2009, 11:48 PM   #2
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
nice install, how much more fluid will it hold now, and $?
Gentry78 is offline   Reply With Quote
Old 06-25-2009, 12:39 AM   #3
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
very cool! that is where techco is putting the heat exchanger for the supercharger on mine. I think a tad bit lower though.
But man that looks sweet, how much did it cost? wondering if i could do that for the oil cause got the LS3
gotpball44 is offline   Reply With Quote
Old 06-25-2009, 12:56 AM   #4
camaro1
camaro1's Avatar
the cooler, lines, fittings, and a couple trips to the hardware store to make the brackets,
total $360, the cooler alone is $200
Old 06-25-2009, 12:58 AM   #5
gotpball44
gotpball44's Avatar
total $360
thats not a bad price at all
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Transmission Cooler Gib Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 04-02-2009 04:13 PM
Which transmission will the L99 have? mega V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 01-08-2009 08:53 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
