sjm autoprod
Old 04-30-2013, 09:49 AM   #1
plus1zero
Back in a V8 ;)
plus1zero's Avatar
Drives: 2013 F-150 5.0 4X4 Screw PAST 2LTRS
What kind of oil do you use?
Time for an oil change. I don't use synthetic, typically I go to Goodyear here in my town and have always had a good experience. What do you guys use and do you do it yourself?
plus1zero is offline   Reply With Quote
Old 04-30-2013, 09:51 AM   #2
SoCal Swagger
SoCal Swagger's Avatar
Drives: RS
mobile one full synthetic.....
SoCal Swagger is offline   Reply With Quote
Old 04-30-2013, 09:53 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Do it myself with Mobil 1. I will be changing to Pennzoil Platinum in the future as it's getting better results on lab test and helps to quite the lifter tick on the SS.
FSP tuned: 377/389
Old 04-30-2013, 10:37 AM   #4
MrWray
SYBIL
MrWray's Avatar
Drives: 2013 2SS/RS, silver ice metallic
i only use Mobil 1 5w-30 Extended Performance, and i also use purolator oil filters
MrWray is offline   Reply With Quote
Old 04-30-2013, 10:45 AM   #5
bw26ss
Banned
Drives: ss camaro
the kind you buy at the store
bw26ss is offline   Reply With Quote
Old 04-30-2013, 10:59 AM   #6
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
What comes stock in the 6.2L engine?
gajagfan is offline   Reply With Quote
Old 04-30-2013, 11:00 AM   #7
WildOne
the "crazy cat" lady
WildOne's Avatar
Drives: 2012 2SS/RS Blk Vrt
Only use Mobil One in all 4 of my cars.
High Octane Club
Mid Florida Camaro Club
Current toys:
2012 Black/IO 2SS/RS Convertible 6 spd "Beauty" ordered 5/31/11 - built 7/28/11 #3616 - 8/18/11 delivered
2015 Corvette Stingray Pacific Edition "Snow" - ordered 3/12/15 - built 4/9/15 - Museum Delivery 5/5/15
WildOne is offline   Reply With Quote
Old 04-30-2013, 11:03 AM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Mobile 1 synthetic 5w-30
That's what I use. As long as you haven't added an aftermarket cam with springs and stuff you should be okay. Otherwise I would consider Valvoline VR1 (non-synthetic).
Build Journal
Old 04-30-2013, 11:04 AM   #9
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Joe Gibbs LS30.
blazzin1 is offline   Reply With Quote
Old 04-30-2013, 11:11 AM   #10
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Amsoil.
Deftones is offline   Reply With Quote
Old 04-30-2013, 11:16 AM   #11
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
We use Mobil 1 on all of our cars!
Team STILLEN is offline   Reply With Quote
Old 04-30-2013, 11:20 AM   #12
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Penzoil platinum after doing much web research.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 04-30-2013, 11:25 AM   #13
Jim968
Jim968's Avatar
Drives: 2013 2SS RS
Mobil 1. Do it myself.
Jim968 is offline   Reply With Quote
Old 04-30-2013, 11:27 AM   #14
plus1zero
Back in a V8 ;)
plus1zero's Avatar
I picked up some Mobil 1 fuel economy, it was less buying synthetic than it was getting them to do it by just doing it myself.
I was under the impression synthetic was really expensive
