Old 04-30-2013, 03:34 PM   #1
intensifi
Drives: '12 2LT Convertible
Question What is the "maximum" scratch you can fix with polishing?
The dealer where I bought my car "washed" with brushes to keep the cars "clean". Because of this I have a few scratches in my hood that are deeper than the "spider web" scratches I'd be comfortable polishing out myself.
What is the safe scratch limit for a novice to polish away?
Any photo samples of the "limit" would be appreciated.
Besides a repaint, are there any options in between polishing and a repaint?
I'm thinking a body shop's stock answer will be "repaint".
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 04-30-2013, 03:38 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Depending on how deep they are, you could try wetsanding. If I were you, I'd try getting some meguires m101 and try polishing it out. If m101 can't get it, then you could try wetsanding or a repaint.
Old 04-30-2013, 03:47 PM   #3
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Here's my best pictures showing what I have been able to take out:
BEFORE:
AFTER:
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 04-30-2013, 04:14 PM   #4
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Not an exact science, but the general rule of thumb is if you drag your fingernail gently across the scratch and it catches, you might have a scratch thats going to require a little more than polishing.
If you can't feel it or your nail doesn't catch its likely going to be pretty easy to polish out.
Old 04-30-2013, 07:30 PM   #5
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
BEFORE:
AFTER:
They need to go to jail for that!
AmericanMuscleCars is offline   Reply With Quote
Old 05-02-2013, 08:11 PM   #6
11VicConSSMan
11VicConSSMan's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
The few times I have been back to my dealer its HANDS OFF in regards to washing.....
11VicConSSMan is offline   Reply With Quote
Old 05-03-2013, 12:45 AM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Unless they were using a soapy rake to wash your car with, I would think you could polish brush marks away.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
polish, scratch
