Flowmaster Exhaust
Old 04-30-2013, 07:02 PM   #1
KSX
KSX's Avatar
Drives: 2010 Camaro 2SS/RS
Cleaning/Polishing the engine?
Hey looking for some tips on cleaning the engine, any good thoughts? Lot's of dust and nasty stuff :P
2010 Camaro 2SS/RS IOM 6 SPD LS3
KSX is offline   Reply With Quote
Old 04-30-2013, 07:10 PM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 04-30-2013, 11:19 PM   #3
mulletman
Drives: 2017 Camaro SS
Buy a gallon of Simple Green at Home Depot. Fill a plastic spray bottle with the Simple Green. Go to a car wash that has the spot free rinse. Don't use the full power setting. Spray the spot free rinse in the engine compartment for a couple minutes. Spray the Simple Green full strength on the engine and inner fenders. Don't get the Simple Green on the paint. Rinse off the Simple Green on the spot free setting. Drive the car until all the water is gone.
mulletman is offline   Reply With Quote
Old 04-30-2013, 11:25 PM   #4
ihaveacamaro
I like teeth.
Drives: #198
I would advise against doing that. It's not that it doesn't work, but that method isn't meant for people not sure about what they are doing.
Old 05-01-2013, 08:05 AM   #5
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
You'll really need to be familiar with what areas of your engine bay need protecting before introducing chemicals and water to rinse those chemicals off the engine bay. (Alternator, battery terminals, etc,)
Plastic grocery bags come in handy for those areas and where appropriate, double bag.
Even after all these are covered you should still take care with how much product and water you use and where you spay. A little goes a long way and use a boars hair brush to agitate the cleaner
Hope this helps
WiSSDiver is offline   Reply With Quote
Old 05-01-2013, 04:44 PM   #6
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
THIS x 10
I am far from a pro but this method works and I have never had any issue after the fact.... no check engine lights and etc.
Laus Deo
charlietuna is offline   Reply With Quote
