Cold Air Inductions
Old 04-30-2013, 09:23 PM   #1
Rhyder
Drives: 2012 45 Anniversary Vert
Convertible Trunk Screen
I did the searchs and found nothing, could be Im not naming it right.
My Q is how do you disable the trunk screen so the car thinks its there all the time? Im planning on getting a stealth sub box, and it says you have to remove the screen.
If its not there, the top wont go down. Is there some way to disable that sensor so you can put the top down anyways?
Rhyder is offline   Reply With Quote
Old 04-30-2013, 10:19 PM   #2
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
I understand 'why' you want to, but I don't think it would be wise. That screen/shelf is there to give the top a place to rest when it's retracted. There is always a way around things.
Since there is not a sensor on the ends of the screen you pull on I would bet it's in the roll up mechanism somewhere.
Is there some way to work around it or is that the only option?
babytiger is offline   Reply With Quote
Old 04-30-2013, 10:25 PM   #3
theragtopguy
Lifetime Phillies Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
There's a magnet in one end of the shaft that gets picked up by the sensor. Not sure which end though.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
One of 82 GF Ragtops built in '15 out of 811 Total
Member of SEPA5+
theragtopguy is offline   Reply With Quote
Old 04-30-2013, 10:27 PM   #4
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
I saw a thread about this a long time ago, but can't seem to find it. I'm fairly certain disconnecting the sensor disables it. So removing the screen will leave your top fully functional.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 04-30-2013, 10:31 PM   #5
pgustavson
pgustavson's Avatar
Found it: http://www.camaro5.com/forums/showth...ht=trunk+nanny
I searched on "trunk nanny"...
Old 04-30-2013, 11:17 PM   #6
Rhyder
thx what I was looking for, figured I just wasnt hitting the right words in search.
Old 05-12-2013, 08:55 AM   #7
RickM
Drives: 45 ann.auto conv.
does a wind screen for the conv. really cut down on cabin noise?
RickM is offline   Reply With Quote
Old 05-12-2013, 10:19 AM   #8
goldappa
Drives: Camaro 2011 RS Convertible
Yes. I would guess about 75% reduction in wind thus less wind noise.
goldappa is offline   Reply With Quote
