BeckyD @ James Martin Chevy
Old 05-01-2013, 07:29 PM   #1
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
yet another Catch Can Question-pics
Searched and couldn't find install info for the "dual valve" ZL1 rev extreme can.
I checked their site, called them, you guys are my only hope.
what hose goes where? I have 3 one does not have a check valve where does it go?
Laus Deo
charlietuna is offline   Reply With Quote
Old 05-01-2013, 09:14 PM   #2
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
Check this out http://www.camaro5.com/forums/showpo...94&postcount=7, hope it helps
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
Old 05-01-2013, 09:21 PM   #3
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
I think he's talking bout the check valves on the hoses.. Link above doesn't show the hoses the op is using.. I have a guess on were they go but doubt you want to guess and want a correct answer.
Al C. is offline   Reply With Quote
Old 05-01-2013, 09:35 PM   #4
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
Go here
http://www.revxtreme.com/instructions/cc_zl1.pdf
13 ZL1 is offline   Reply With Quote
Old 05-01-2013, 11:29 PM   #5
charlietuna
Drives: 2013 ZL1
I think I have it installed correctly. My only question and I have read all the install info on revextrem's site, is where the hoses connect to the can. One of my outside fittings goes to the cai the other to the intake manifold I think I have it right I just don't feel 100%
I left a MSG at revextrem and I hope they call me back tomorrow early.
Thanks for the help and support as always.
Laus Deo
Old 05-01-2013, 11:38 PM   #6
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
You only need a in and out on the CC for a ZL1, the other line is not needed.
Putting the 3rd line to the bottom elbow will only let oil bypass to be going in front of the TB. Better not to let any air oiled go in front of the TB.
You just need one line that goes to the Valley pan, that is dirty air oil and it goes to CC then out to the blower snout PCV valve.
There is a clean air make up that goes from bottom of elbow to both valve covers and that is to let clean air IN to the engine, that is all you need. 3rd line is for set ups that add a blower, the ZL1 comes OEM with the blower.
Skylane765 is offline   Reply With Quote
Old 05-01-2013, 11:51 PM   #7
charlietuna
Drives: 2013 ZL1
Ok now I'm confused. When I called revex they were informed about my year make and model. How can I have this wrong. I am installing the no tune cai in a week after a base dyno pull and intend on joining the cai with the catch can. The folks at rx were apprised of my intentions prior to purchase.
Laus Deo
Old 05-02-2013, 12:02 AM   #8
Skylane765
Skylane765's Avatar
The 3rd line is not need on a ZL1, you only have a In and out to a CC. Even with CAI you only need a in and out, that is what you have on the car. The line to the CAI is to the engine for clean air to get in. Just block the 3rd line on CC.
I have a smog lic and the ZL1 with Roto fab CAI. I installed a CC with only two lines.
For what reason do you want air oil in front of the TB. You do not need the CAI connected to the CC only to the valve covers.
Old 05-02-2013, 12:09 AM   #9
Skylane765
Skylane765's Avatar
Do you know how the PCV system works on the ZL1? What are the check valves for? The car does not have them with or with out a CAI. I have the service manual to the ZL1 and the PCV system is simple when it is connected to the blower snout, because it is under vacuum even with boost, so no 3rd line needed.
If you have a SC added to a engine, then in some cases the 3rd line is need under boost, that is not the case with our ZL1.
Old 05-02-2013, 07:27 AM   #10
jbotta
jbotta's Avatar
Drives: Camaro ZL1
Thays good to know im about to order mine.
jbotta is offline   Reply With Quote
Old 05-02-2013, 07:34 AM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
read the first paragraph of the install page....disregard all of the other trash talk on this thread. With the ZL1 we use the dual valve can system with the center fitting on the can connecting to the valley cover vent tube and one outer valve to the vacuum barb that did run to the valley cover tube, and the other outer valve to the main air intake tube.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 05-02-2013, 07:35 AM   #12
Jeff65SS
Jeff65SS's Avatar
Drives: 1965 Chevelle Malibu SS
Revextreme recommends the 3 hose model over the 2.
Jeff65SS is offline   Reply With Quote
Old 05-02-2013, 07:51 AM   #13
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
i have the 3 hose catch can, one of the first ones in fact. the can is very efficient and after 7 months i have had no oil suck back through the throttle body. of course i broke my car in like john force would and i get less oil going into my can than the people who are following the g.m break in period to a t. tracey at rev ex even commented how well my rings seated compared to some other Z owners who babied through the break in. i empty my can every other oil change and get maybe an ounce or 2 of oil out of it at that frequency. even rotofab now includes a tee for the people using the 3 hose can. i got to see first hand how clean the plenum was as i had a bad blower snout at 8k miles and dealer took off and replaced the whole supercharger. at that point even the tech said he never saw one so clean inside ever.
joes407 is offline   Reply With Quote
Old 05-02-2013, 07:58 AM   #14
jbotta
jbotta's Avatar
Drives: Camaro ZL1
Ok, I have the tee from rotofab, so dual can cant hurt. Do you have pics, did you mount it at thr radiator, sorry my typing sucks
