Old 05-03-2013, 02:56 PM   #15
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
Originally Posted by lscamaro View Post
Completely get what you're saying. I've encountered a few of those and I hate them. The more laid back dealers, I really like
Amen!
Indy Bumble Bee is offline   Reply With Quote
Old 05-03-2013, 07:07 PM   #16
TooCool5
TooCool5's Avatar
Try a fuse pull to re-set everything.
Old 05-03-2013, 07:58 PM   #17
DJ ATOMIX
<< CRAZY BEE >>
DJ ATOMIX's Avatar
Drives: 400HP 2LT/RS
X2 on that plus if the op is still skeptical, a dyno might not be a bad idea. Car should be around 250-260rwhp with the cai on a dynojet. If your getting 220rwhp or something low like that then there is problem.
Also maybe another oil change could directly affect tje cars performance. If the car had some bad oil or low on oil, you would loose power.
CRAZY BEE - IOM 2LT/RS (more)
Cosmetic Mods - 24 | Performance Mods - 14
ROTO-FAB CAI - DT HEADERS - CUSTOM 3-INCH PIPE EXHAUST - RES DEL - R-CATS DEL - MAGNAFLOW RES X-PIPE - 91 OCTANE TUNE - FULL ADM KIT - PORTED IM - PORTED TB - PORTED CH - BLACK 3/8 ISOLATOR - TRIFECTA TUNED
DJ ATOMIX is offline   Reply With Quote
Old 05-04-2013, 08:14 AM   #18
SC2150
I am willing to bet if a service center did the repair they have the timing off a tooth or two. Will still run decent, but power will be flat.
Old 05-04-2013, 12:53 PM   #19
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
There is no way a Purolator oil filter would have caused the damage. Hope you get the power issue figured out.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 05-04-2013, 03:52 PM   #20
SC2150
Agreed. Purolators are great. They just want to place blame elsewhere.
Old 05-11-2013, 01:12 AM   #21
Ocx
Ocx's Avatar
Drives: 2013 Camaro 2SS/RS
Pulling fuses #5 and #20 to see if this will help. GM has been notified of the issue, they've contacted the dealership. I was out of town on business this entire week, dialing into it now.
Ocx is offline   Reply With Quote
Old 05-11-2013, 10:13 AM   #22
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Fuse pull on a V6?
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 05-11-2013, 10:55 AM   #23
SC2150
Not on the LLT V6.....but I stand by my guess on the timing. We do these non stop here and it is easy to be a tooth or so off and have low power when it sounds fine.
The problem with a "comeback" though is the tech will have been payed flatrate on the job and now has to tear down and fix w/out being paid. He wont want to do that.
Old 05-11-2013, 11:46 AM   #24
911medic
911medic's Avatar
Originally Posted by 911medic View Post
Fuse pull on a V6?
Originally Posted by SC2150 View Post
Not on the LLT V6.
Does it work on the LFX? I thought it was a V8-only trick.
Old 05-11-2013, 02:35 PM   #25
SC2150
LFX you can disconnect the negative cable (I'm not sure which fuses to pull) and rest octain tables as they have a GM PCM where the LLT has a bosch.
Old 05-11-2013, 04:54 PM   #26
911medic
911medic's Avatar
I did not know that. Thanks.
Old 05-13-2013, 11:08 AM   #27
Ocx
Ocx's Avatar
I tried the fuse pull, didn't help as already stated...worth the try at this point.
Issues noticed:
-Idle RPM seems to hover around 600-700 RPM's.
-RPM's at 50-60mph are around 1200 rpm's where before they were around 1800-2000. I have to give the car more gas on the pedal to maintain a constant cruising speed. Hard to describe but it seems like I have to give it more gas to maintain the same cruising speed. When I give it a little more gas to maintain speed on a hill for example, it not downshifts instead of before it would stay in the same gear. It kind of bogs down before it shifts. The gas pedal is not the same "shifting point".
-Won't break loose from completely stopped. It's like it lost all 1st gear acceleration.
-1st gear ratios are decreased significantly. Before if I was in 1st gear and didn't shift I would get to maybe 15mph. Now I can use 1st all the way up 30mph before shifting.
Sounds like you could be spot on?
Old 05-13-2013, 11:17 AM   #28
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
if the rubber seal on the filter was the culprit, wouldn't you have noticed a pool of oil?
