SDTW Custom Wheels & Tires
Old 05-02-2013, 02:54 PM   #1
Ntmd8r
Ntmd8r's Avatar
Drives: 2012 Black 2SS/RS L99 A6
Severe Oversteer
2012 2SS RS L99 A6 FE4
Stock 20" wheels and P Zero tires.
5500 Miles
My daily driver.
My style of driving is called "Spirited".
I have been autocrossing for over 30 years
(with Corvettes, now with 2007 Corvette LS2 Z51, Pfadt Sway bars, Coil-overs, R888 Tires)
So I do know how a car should handle.
This Camaro is a "beast".
With my spirited driving style, whenever I want to take a corner with gusto
I really have to wait till the car is almost straight after the turn before giving it some gas, otherwise the rearend is coming around to kiss my frontend.
If I merely take a corner too fast, with no acceleration, the rearend starts to slide out, and I have to brake to get rear adhesion.
Usually north american cars have Understeer built in.
But this is severe oversteer.
How about it Suspension guys..... I can't adjust the rear bar on FE4 (I don't think), different bushings ?, alignment ? ...... or ??????
Thanks for any help
(Oh, I do plan to install Michelin PSS tires in a few months... these P Zeros are terrible)
2012 2SS RS Black L99 A6
Heritage Grill,
Janetty tune,
SLP Loudmouth exhaust,
CAI intake,
RPI Splash guards
C7 Triple Black Z51 MN6 Convertible ordered
Ntmd8r is offline   Reply With Quote
Old 05-02-2013, 03:07 PM   #2
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
what tire pressure are you using?
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 05-02-2013, 03:21 PM   #3
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Is it the same with and without TC on? L99 is an auto trans right? Is it down shifting hard?
jeremywes is offline   Reply With Quote
Old 05-02-2013, 03:57 PM   #4
SPCBA
Drives: pleather and Chiclets
your stock suspension and have oversteer? i am so confused. if your stock and have oversteer either somethings wrong or you cant drive.
SPCBA is offline   Reply With Quote
Old 05-02-2013, 04:42 PM   #5
Ntmd8r
Ntmd8r's Avatar
Mikamaro... 36 lbs
jeremywes... sorry... haven't tried it with TC on.
It is not downshifting at all... just maintaining a good speed around corners.
SPCBA... thanks for your help
Heritage Grill,
Janetty tune,
CAI intake,
RPI Splash guards
Old 05-02-2013, 04:50 PM   #6
HBMike
HBMike's Avatar
Drives: 2010 Synergy Green HBR
Its shit tires. I run a 285 front 315 rear. Makes a big difference. You also need to set your camber correctly and go to a nice double adjustable coil-over.
Being you're stock it could be your body roll momentum swinging you around. the cars are definitely setup to plow from the factory unless you're turning super sharp.
Wilwood 6 Pistons -Magnaflow X-Cat back - CDC Havoc Styling - TSW Wheels - Roadwire Custom Green Leather Interior - Hotchkis Race Suspension - Whiteline Flatout - KW V3 Suspension - 3M Wraps - Toyo Tires - IPF Supercharger - Vortech V3 - Airaid Filters
HBMike is offline   Reply With Quote
Old 05-02-2013, 04:50 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Your pressure seems okay, and T/C should not matter.
Are you sure you are on stock sway bars? Because you are correct, it should have understeer.
You may consider going to the Pfadt ZL Spec sway bars. They have 3 stiffness adjustment settings front and rear, so you can fine tune the under/over steer to your driving style and tire selection. You also may want to try a more staggered tire setup and put the rubber where you want it.
Best regards,
Tyler
888-308-6007
Old 05-02-2013, 05:16 PM   #8
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
This I do not understand. Applying brakes when the back end is trying to come around should make it worse.
Iron Lung Jimmy is offline   Reply With Quote
Old 05-02-2013, 05:54 PM   #9
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
These cars are known for severe understeer, hence the 1LE package. Something isn't right with you or the car.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 05-02-2013, 06:07 PM   #10
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
^^This. The Camaro has never had a particularly good chassis (at least in terms of handling) without shelling out for a 1LE or ZL1. And the tendency of them at the limit is normally toward significant understeer.
"Proven V-8 power with better efficiency than a turbo V-6"
"The car is the closest thing we will ever create to something that is alive."eds.
fielderLS3 is offline   Reply With Quote
Old 05-02-2013, 08:40 PM   #11
Ntmd8r
Ntmd8r's Avatar
Iron Lung Jimmy.... I apply the brakes to slow it down..... to stop the rear from sliding out. And that works.
Tyler... I think it is stock FE4... I am not the first owner, but I got it from a dealer so
not sure if anything was done... but everything else was pristine... so I think nothing was done.
FE4 should make it turn better (I expect), and I don't think it is adjustable.
With the new Michelin tires I plan to go with the stock wheels and
285x35 Rear
255x40 Front
And I will make sure I have some camber in the rears with zero toe.
I was just wondering if anyone had any similar action on their car.
Thanks guys, for your input.
Heritage Grill,
Janetty tune,
CAI intake,
RPI Splash guards
Old 05-03-2013, 01:47 PM   #12
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro SS, 2014 Z28
As everyone has chimed in, these things are prone to understeer. When I set up my car (F/R coilvers, Pfadt Racing ASB's) at maximum stiffness, I do get a little oversteer. Then I just back off on the rear's settings and seems to get right. Something is way out of whack to get oversteer on stock components
ERL 500 ci Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, MGW Shifter, StopTech BBK, Pfadt C/O's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
Old 05-03-2013, 03:45 PM   #13
Mikamaro
MikeNoMaro
Mikamaro's Avatar
[QUOTE=Ntmd8r;6498184]Iron Lung Jimmy.... I apply the brakes to slow it down..... to stop the rear from sliding out. And that works.
not sure if anything was done... but everything else was pristine... so I think nothing was done.[QUOTE]
Assuming is not a fact.
Put it on a lift and ask the dealer to check the suspension parts.
If stock, it's not normal...unless you drive like a maniac on purpuse.
Good luck!
Old 05-04-2013, 05:18 AM   #14
Denis
Denis's Avatar
Drives: 2010 SS
thats odd. i wish i had more oversteer. that damn understeer kills me. The suspension is the next thing to be tweeked.
