Gen5DIY
Old 06-25-2009, 12:39 PM   #1
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
L99, A6 (1st gear discussion?)
I'm trying to clear up the confusion about the A6 not starting out in 1st gear. It does start out in 1st gear when using regular D (drive) and M (sport mode).
If you're in D (regular drive) or M( sport mode) and you start out from a dead stop and mash the gas, 1st gear will hit redline at 35-37mph and shift up to 2nd gear. It does this in D, and M mode (not using paddle shifters).
If it was starting out (dead stop flooring the gas) in 2nd gear it wouldn't shift until 60-70mph (where ever the 2-3 shiftpoint is).
So Yes, the A6 starts out in 1st gear when in D (regular drive) and M (sport mode).
Thanks
Old 06-25-2009, 12:44 PM   #2
toehead93
Drives: 2014 2SS/1LE
The only time the car will start in 2nd gear is if you are manually shifting up the gears, come to a complete stop and don't manually downshift. The transmission will down shift for you but only to 2nd gear.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 06-25-2009, 12:47 PM   #3
SGOS252382
SGOS252382's Avatar
That makes sense.
There's been a lot of confusion and a lot of people think the A6 only drops to 2nd gear when driving around in D or M mode.
Old 06-25-2009, 04:05 PM   #4
kdoske
Waiting For My 1SS/RS SIM
kdoske's Avatar
Drives: Sold My Lancer, now carless :/
why is the gear number not shown on the DIC when in M mode or is it? If it isn't that thats just strange...
Order# NJPW8K
1SS/RS SIM Black Interior
1100 (original order date): 04/16/09
2000 (dealer received allocation):
2500 (order preferenced):
3000 (accepted to production):
3300 (scheduled for prod):
3400 (broadcast):
3800 (produced):
4000/4B00 (available to ship/bayed):
4200 (shipped):
4300 (intermediate, may be multiple):
kdoske is offline   Reply With Quote
Old 06-25-2009, 04:21 PM   #5
SGOS252382
SGOS252382's Avatar
I drive with the speed of the car showing in the DIC. I know that when its in M mode and you've initiated the tap shifts, it shows you what gear its in. But in D or M mode (without using tapshifts) it doesn't show what gear you're in. It just shows M and S (s for sport).
Unless there's a different mode of the DIC that I haven't discovered yet.
Old 06-25-2009, 11:08 PM   #6
Inferno RS/SS
Drives: 2010 2SS/RS, 86 Grand National
This quote is from another thread, "The L99 6-speed automatic only starts off in 2nd if you are in A position, or if you are in M position running in Sport mode. If you are in M and run with the Trip-Tronic you can kick it into 1st with a flick of the left flip-off finger."
Inferno RS/SS is offline   Reply With Quote
Old 06-25-2009, 11:24 PM   #7
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
this have been discussed so many times. "m1" doesnt show up when you shift to M because it is in sport mode, a completely different mode than the paddle shifters. to start the using the paddle shifters you have to click on of them.
trudawg660 is offline   Reply With Quote
Old 06-25-2009, 11:38 PM   #8
Rodrunner
Senior Member
Rodrunner's Avatar
Drives: 2010 SS/RS, '06 350Z
When you first put the shifter to the M (manual) position at highway speed, the DIC simply shows S for Sport mode, no downshift occurs as with my 350Z. As soon as you downshift, it displays S5, S4, etc., but will only drop to 2nd gear, unless you hit the "-" tapshift button when stopped. The manual says, "A 1st gear start can be selected by using the Tap Shift controls on V8 models." See section 8 page 29.
2SS/RS - Black/Black - CGM Rally Stripes - Auto - VIN 10171
Rodrunner is offline   Reply With Quote
Old 06-26-2009, 07:57 AM   #9
Inferno RS/SS
The question is whether or not the A6 will start out in 1st gear in any mode other than M-with paddle shifters.
Old 06-26-2009, 08:10 AM   #10
mlee
www.CamaroFans.com
mlee's Avatar
Drives: 2017 A10 ZL1
Would probably help the 0-60 times if you could start out in 1st gear without using TapShift. Only way I know to get to first is to Tap down, but then you are stuck having to launch and continue using TS.
Old 06-26-2009, 08:50 AM   #11
SGOS252382
SGOS252382's Avatar
YES.
That's what I've been saying.
My A6 starts out in 1st gear everytime from a dead stop using regular
D (drive) and M (Sport mode).
The only time I will NOT start out in 1st gear from a dead stop is when using the tap shifts. If you're in M mode and using the Tap shifts you must manually drop it to 1st gear. Otherwise it will start you out in 2nd gear from a dead stop.
This is where all the confusion started.
But yes, the A6 starts out in 1st gear (from a dead stop) automatically in every driving mode except (manual tap shift mode).
Old 06-26-2009, 09:04 AM   #12
trudawg660
Originally Posted by SGOS252382 View Post
YES.
And what makes you say that it starts in second when you use the tap shift
Old 06-26-2009, 09:13 AM   #13
mlee
www.CamaroFans.com
mlee's Avatar
OK... I tried this morning.
- While driving in Auto. Pulled back to M (30mph) and never touched the shifters
- Came to complete stop still never touching shifters
- Slowly took off to 1500rpm and downshifted (one left tap)
Result... RPMs shot up due to downshifting from 2nd to 1st.
Hopefully I can be proven wrong on this one....
If you are using Tap Shift it's going to start in whatever gear you left it in.
Old 06-26-2009, 10:27 AM   #14
trudawg660
if you’re at a dead stop and you shift to "M" and you click the right paddle "M2" comes up. if you shift you "M" from a dead stop and click the left paddle "M1" comes up. ok with this being said when you shift to "M" if you are in second gear why don’t the car try to shift to 3rd when you click the right paddle.
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
2010 Camaro Review Compilation Tran Camaro Price | Ordering | Tracking | Dealers Discussions 213 07-29-2011 02:59 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Clarification Please! L99 and 1st gear Ace 5th Gen Camaro SS LS LT General Discussions 6 05-22-2009 04:34 AM
L99 discussion The_Blur Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 07-25-2008 03:07 PM
