HeadlightArmor
Old 05-03-2013, 12:18 AM   #1
con10der
Con10der
con10der's Avatar
Drives: 2010 2SS/RS M6 IOM Rally Stripes
Hard Wiring Radar and Phone charger units
I have a request from any sparkies out there.
I want to hard wire my Radar detector to a "hot" (always on) power source in my overhead console. Can someone instruct me on this task? Is there a source there to tap into? Can you tell me the color/polarity of the wires I require?
Same question, although for Phone charger and power source from lower center console.
Any input would be greatly appreciated...Thanks!
2010 2SS/RS M6 IOM w/Rally Stripes. BLK CAI w/ADM,WW Relo,2" Kooks,3" Cats-Mids,Vmax Ported TB,Muff Del,Janetty SCT Tuned,Drill/Slot BLK Hawk rotors,Red Grani Brake Lines,Motul 600,IDEAL Master w/res,Moroso CC,Accel Silver Tips w/TVolt 10.4mm,MGW shift w/Retro hand/ball,ABL Kit,Billet/IOM pedals, ZL1 split,Lloyds SS mats,PC Droid4/MAXX docking,HW Solo2.
Pend Install: Launch/Shift Light,BMR Susp/1" Drop/Sways/Track Pack,GM 3.9. Future: Janetty Pumpkin w/PosiTrac,1400HP axl,CF DS,Tick Stage 2 Trans,3 Disc Clutch,4"quad tip,center exit AB w/diff...
con10der is offline   Reply With Quote
Old 05-03-2013, 08:43 PM   #2
CyberPunk223
Drives: 2012 LS Camaro
It's actually easier to run a power line down to your fuse box for the radar detector and use a fuse tap in than it is to take apart that dumb overhead console. I happened To take apart the overhead console just to put a switch in for my radar detector which was pretty dumb because it wasn't worth the effort.
rather than hard wire a phone charger why not just get a PDIM USB connection so you can charge & play music too?
if you really want there are lots of threads that show how to take apart both of those things.
CyberPunk223 is offline   Reply With Quote
Old 05-03-2013, 09:16 PM   #3
mattyjman
Drives: 2013 2SS 1LE
do you have power mirror? if so, you can tap right there.
otherwise, getting the overhead console off is a pain if you haven't done it once before.. it will stump you for an hour, easy...
sounds like cyberpunk has a solid suggestion... dpending on where you mount the radar (i prefer mine higher, others are lower) run your wire around the headliner (windshield if lower), down the a pillar, to the fusebox on the drivers side.
mattyjman is offline   Reply With Quote
Old 05-03-2013, 09:25 PM   #4
ec1990
Drives: 2012 AGM SS
I used the drivers side fuse box Inside the cabin. Just used a tap a fuse connector for that and a dash cam. Works like a charm, ran it up the a pillar and headliner.
ec1990 is offline   Reply With Quote
Old 05-03-2013, 09:27 PM   #5
Meister
Meister's Avatar
Drives: 2016 Corvette Stingray Z51
Did the same for my V1. There is a pretty good DIY write up for that posted here somewhere.
Meister is offline   Reply With Quote
Old 05-03-2013, 09:52 PM   #6
CyberPunk223
I just look up the PDIM, it costs more than I though It did, by the time you get your HU flashed your into it almost $200... it's hard to justify spending that much for a phone charger. there are lots of other USB interface devices, PAC makes a bunch of them,, they are cheaper but quality may not be as good.
Old 05-04-2013, 03:55 AM   #7
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
This is how I did mine, I made a DIY thread on it. It works perfectly for my iphone, feel free to PM me if you have any questions
http://www.camaro5.com/forums/showthread.php?t=282062
Aubrey64 is offline   Reply With Quote
Old 05-11-2013, 05:15 PM   #8
Camaroshark
Drives: 2010 Camaro 2SS/RS RJT, 6speed
I did the mirror tap wire for the powered mirror. I'm using the passport ... through for the DIY for the mirror tap wire and hard wiring the radar detector
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
Camaroshark is offline   Reply With Quote
