Caryle Racing
Old 05-03-2013, 05:18 AM   #1
ilpezzillo
Drives: hiunday getz
information from italy :D
hi, this summer is going to travel on the road with the camaro, I just wanted to know what kind of fuel should I use
thanks
ilpezzillo is offline   Reply With Quote
Old 05-03-2013, 06:00 AM   #2
oklapike
oklapike's Avatar
Drives: 2012 45th Anniversary SS Coupe
Whereabouts do you plan to travel, Europe or the United States? Do you plan to rent a Camaro; if so, were you looking for a V6 model or a V8 model? V6 models don't require a specific grade of fuel, but if you have (or are planning to rent) a V8, you'll need to use premium fuel. 93 octane is best if you can find it, 91 octane works fine if you can't find 93.
oklapike is offline   Reply With Quote
Old 05-03-2013, 06:09 AM   #3
ilpezzillo
thank you for reply...
i'm renting a camaro for a long road trip on the west coast...4500 miles
p.s. v8
Old 05-03-2013, 08:42 AM   #4
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
If you're renting then use the cheap stuff.
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 05-03-2013, 08:44 AM   #5
ilpezzillo
really?
Old 05-03-2013, 08:46 AM   #6
msp2887
msp2887's Avatar
Drives: 2011 2SS/RS Black
Why use the cheap stuff? It's just going to knock it down to the 87 Octane table and make the rental less enjoyable.
msp2887 is offline   Reply With Quote
Old 05-03-2013, 08:58 AM   #7
sloSS
sloSS's Avatar
Drives: 2012 Camaro 1SS RS LS3
Since the car is a rental, chances are someone (many?) before you ran 87 octane in it.
Run the first tank of fuel until the low fuel light comes on then fill with 93 or 91 as available in your area. Then pull the fuses overnight to reset octane table, enjoy your new found power for the rest of your drive!
sloSS is offline   Reply With Quote
