Old 05-03-2013, 01:04 PM   #1
Camaro154
Camaro154's Avatar
Drives: 2012 2SS CAMARO IOM
Is the Meguair's DA power system kit any good?
I have swirl marks in my car and a friend at work said he uses this system. It attaches to a drill and you use it to polish or wax your car. I have also been looking at the porter cable 7424xp which I know is good. I just wanted to see if anyone had an experience with the Meguairs DA power system because it is a much cheaper route to go. You can see the product on the link below.
http://www.amazon.com/Meguiars-G5510...a+power+system
Camaro154 is offline   Reply With Quote
Old 05-03-2013, 04:21 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Personally, I wouldn't go that route. Haven't seen it in action but I highly doubt it can come close to a good DA. The XP is a good one and I hear good things about the Griots. You'll pay almost double for the ones below but they are far better solutions.
Autopia
http://www.autopia-carcare.com/dual-...polishers.html
http://www.autopia-carcare.com/porter-cable-combo.html
Autogeek
http://www.autogeek.net/poca74pofcop.html
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-03-2013, 04:24 PM   #3
Camaro154
Camaro154's Avatar
Thanks for the reply. I think the Meguiar's option would be more difficult to work with also because you have to hold the drill up for a flat surface contact. I just thought I would ask because I did some searching on the forum and could not find any posts on this kit. Thanks
Old 05-03-2013, 04:33 PM   #4
warren3537
warren3537's Avatar
Drives: 2017 Red Hot 1SS
I bought the Meguairs system at Wally World, and I think it does a good job on my Camaro, I use the Adams 4 inch pads and it has made my car shine and it is good for the areas that are too small for the 6 inch.
warren3537 is offline   Reply With Quote
Old 05-03-2013, 04:49 PM   #5
axis
Search Ninja
axis's Avatar
I'm sure it would work fine for applying waxes/sealants but paint correction needs some power behind it and the ones you and I mentioned are almost fool proof. Most of the better waxes go on and off so easy, you don't need a machine to apply them.
Halltech CF 102 fed
Old 05-03-2013, 06:13 PM   #6
warren3537
warren3537's Avatar
For a little DA polisher it does work, I use the swirl and haze remover and fine machine polish and finish with sealant, no water spots and nice and shiney.
