BORLA
Old 05-03-2013, 01:58 PM   #1
FJ60
Drives: '13 2SS RS 1LE ; '85 Landcruiser
Gauge Pack Sensitivity
How sensitive are the 4 gauges near the shifter? The oil pressure and oil temp gauges on my '05 Legacy continually moved based on driving conditions, whereas the gauges on my '00 F-150 were stuck at midlevel regardless of how hard or easy I pushed the engine (basically idiot lights with a needle). A video of how they move (or not) while revving your engine would be much appreciated!
FJ60 is offline   Reply With Quote
Old 05-03-2013, 03:18 PM   #2
a.morblu
a.morblu's Avatar
Drives: 2011 Sinister SS
Good question. I just installed these myself and wondered about how sensitive they were to changes in driving conditions.
a.morblu is offline   Reply With Quote
Old 05-03-2013, 03:50 PM   #3
SS_Los
SS_Los's Avatar
Drives: 2011 CGM 1SS L99
Good question, I'd also like to know. I'm about to pull the trigger on this mod for a really good price.
SS_Los is offline   Reply With Quote
Old 05-03-2013, 03:50 PM   #4
TPAJETSKI
TPAJETSKI's Avatar
Drives: Camaro
I remember in the fourth gens that up until 97 the gauges functioned as a regular gauge and were linear. Owners were freaking out because the temperature gauge would creep up in traffic. GM decided to change to an "idiot light" gauge that only moved when it reached a critical level. I know...this is of no help to you at all...sorry.
TPAJETSKI is offline   Reply With Quote
Old 05-03-2013, 04:07 PM   #5
mikeyg36
mikeyg36's Avatar
Drives: 2015 Z/28 #533, 2016 2SS
I know there's about a 2 second lag on the pressure gauge. I never bothered looking for movement on the temp.
“Driving a muscle car fast isn't that fun, it's driving one slowly and making a ton of noise and pissing people off, that's what’s fun.” –Matt Farah
mikeyg36 is offline   Reply With Quote
Old 05-03-2013, 04:09 PM   #6
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
The 4-pack gauges are sensitive enough to work correctly. I haven't had any issues with them, or much of a lag.
I step on the gas, oil pressure rises as expected. Volts are accurate to what they should be, and verified with an OBD scanner.
I assume the other 2 work fine too.
GEEKFREEKSCOTTY is offline   Reply With Quote
Old 05-03-2013, 04:10 PM   #7
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '18 E'nox Pre 2.0T
I see fluctuations of all; oil pressure from stoplight to highway speed increases from approx 35 to 70; trans temp will increase with driving up to about 200 or so; voltage holds fairly constant at approx 13.5, dropping slightly lower after first 10 minutes (after recharging battery from start); oil temp mimics trans oil, but slightly higher. All fluctuations are within the normal range of expected indications.
RJT Impala is offline   Reply With Quote
