JDP Motorsports
Old 05-04-2013, 01:06 PM   #1
ExtremeSS
RobSS
Drives: 2013 Camaro SS, Summit White, 6 SPD
Thumbs up Rapid Fire Tail lights
I have read some of the reviews before installing my tail lights and decided to take some precautionary measures. Removed the lights from the box and inspected them finding several areas where the lens was sealed back on to the housing that had very small holes (not sealed). So I sealed all of these with some clear silicone and let it cure. I also found a screw halfway screwed in where the two part housing connects together with the colored gasket and tightened it up. I would recommend a full inspection when unpacking your lights to prevent problems after installation. I will be installing an interrupter switch on the pink wire which goes to the battery, to try to prevent battery drain (when storing the vehicle for several weeks) that so many reviewers have complained about. I will also be connecting a switch to the ground wire for the show mode as suggested in the instructions. These two switches should eliminate all battery drain, as the factory harness connections do not apply any power to the lights at all when the car is off and stored. I will just have to remember to turn on the power before driving the vehicle, problem solved I THINK.
ExtremeSS is offline   Reply With Quote
Old 05-04-2013, 07:01 PM   #2
ExtremeSS
RobSS
Rapid Fire mod finished
These tail lights took 3.5 hours to install, with two switches mounted under the dash for full control of power and "show mode". I will say that were they tell you to install the capacitors is not a good location so I went to the right side of inside tail light on the left of car and left side of the inside tail light on right side of the vehicle, this allows you to access all nuts and bulbs in the future without having to remove them. Also, I installed the bulb housing after installing the light housing without to much trouble, their way is much harder. Tip- use silicon on the inside of your wrench to hold nut on it for replacement onto the stud, so you don't drop it inside the car body. The show mode is not in time with each other in flash sequence, it is getting better as they warm up, but not impressed with the out of sequence flashing, YES, before you ask did I install them correctly. Turn signals, hazards, brakes and running lights all work great. They do look awesome on the car. I would recommend them.
Old 05-04-2013, 07:16 PM   #3
MistyBlu10
GOBLIN
Drives: 2015 SS Convertable Green Flash
I have them hard install but done now 6 mths no issues at all and garage kept I love them with the ghosted side markers really sets them off
2015 2SS Green Flash Edition
2012 Camaro LFX 45th born 9/24/11 sold 4/1/15
2013 Equinox LTZ
2013 Cruze LTZ
2010 LT2 BLUE RS CAMARO TRADED FOR 45TH
2011 COLARADO Z71 TRADED FOR MALABU
2011 MALABU LTZ TRADED FOR BLUE CAMARO
2007 Z71 Avalanche LTZ
1987 K5 Blazer
BOWTIES AS BLOOD CELLS
GM RULES
MistyBlu10 is offline   Reply With Quote
Old 05-04-2013, 10:22 PM   #4
ExtremeSS
RobSS
6months
That's good to hear, hopefully they will continue to be bad azz with no problem. I have to say I love my lights, just went for a cruise in the rain to check for fogging and leaks, it's been raining all day and no fogging or moisture inside.
Old 05-06-2013, 12:45 PM   #5
ExtremeSS
RobSS
Well after a lot of testing and watching the light sequence on the tail lights in show mode they do not perform as the sales video on the websites selling the Rapid Fires. The sequence is completely off, it is still pretty cool but I really expected the show mode to be as advertised and in sequence as shown. Now I am not sure what steps I will take from this point, it is a lot of work to pull all of those lights back out and try to get them to send me a new set, then do a repeat of the install, a bit disappointed for the money spent. Will update everyone when I get back in town as to what I will do with them.
Old 09-29-2014, 07:46 AM   #6
HeLLDaFieL
HeLLDaFieL's Avatar
Drives: 2013 Camaro 1LE 2SS
Originally Posted by CreativeDawn View Post
I recently made a purchase of the Technostalgia Rapidfire Tail Lights from Gen5Camaro Lighting. I've messaged them SEVERAL times without a response. Does anyone in these forums know about them at all? Are they legit? I'm getting worried, and about to call my credit card company to have things reversed if I don't get a simple answer from these guys.
According to their website, they're a new vendor for Technostalgia. I'd like some helpful feedback! If anyone works for them, i'd LOVE a simple response on my order. Thanks.
It's all on back order, Technostalgia dropped the ball, or didn't count how many people really like those lights. I hope you got yours already.
HeLLDaFieL is offline   Reply With Quote
Old 09-29-2014, 09:54 AM   #7
fastforwarddad
Drives: 2012 ZL1
I ordered the next generation of technostalgia LED tails from from Apex and had them very quickly. These are the updated ones that are supposed to cure battery drain problems.
Thanks Victoria!!!!!
fastforwarddad is offline   Reply With Quote
Old 09-30-2014, 08:44 AM   #8
Niceun
Niceun's Avatar
Drives: 2012 45th edition RS 2LT
Hey guys, I ordered my technostalgia Rapid Fire tail lights from Rick's Camaro (Great folks to deal with) anyway like I said I ordered mine on Aug. 23 and just got an email from UPS saying they will be here tomorrow! I am excited but nervous about the quality of this product. Hopful I won't have any issues.
Niceun is offline   Reply With Quote
Old 09-30-2014, 11:52 AM   #9
TommyTheCat
SHKE BKE ☪
TommyTheCat's Avatar
Drives: 2013 Camaro
Mine work perfectly except that one has a dim LED in the afterburner and two of them get condensation in heavy rain, but even though they have been out of warranty for a while they are going to cover everything for free including a new afterburner. Todd and technostalgia will help you out if you have any issues, they should not take too long to install. took me an hour or so and i took my time
TommyTheCat is offline   Reply With Quote
Old 09-30-2014, 01:42 PM   #10
Niceun
Niceun's Avatar
Thanks Cat, I have read just about every post that has been made on this topic. Watched a lot of youtube so hopefully I am informed enough to get this install done. Also will look for a good seal around the lens before I do the install.
rapid fire, tail lights, technostalgia.
