Gen5DIY
Old 05-04-2013, 10:26 PM   #1
tonyko1
Banned
Drives: 2012 Camaro 2SS/RS Convertible, IBM
Water Spots...
Hello all:
I love this forum, but finding an old thread can be tough. I know there is a cleaning/waxing forum page section, but finding what you need ..........
Well, my Imperial Blue Metallic, (IBM) Camaro seems to be severely afflicted with water spots that just won't go away, easily. Just moved to a new place so it may be the water, but in any case, if there is some type of liquid polish that is quick and easy, my life would then be complete.
Thanks.
tonyko1 is offline   Reply With Quote
Old 05-04-2013, 10:32 PM   #2
dkp2LT
dkp2LT's Avatar
Drives: '10 2LT/RS, '13 GT/CS, '10 Flex
Have you tried clay?
dkp2LT is offline   Reply With Quote
Old 05-04-2013, 10:35 PM   #3
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
clay and remember to wax right after or use a sealant to prevent those pesky water spots!
AmericanMuscleCars is offline   Reply With Quote
Old 05-04-2013, 10:37 PM   #4
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
Wash with a 50/50 mix of vinegar and water.
Then stay away from sprinklers.
upflying is offline   Reply With Quote
Old 05-04-2013, 10:57 PM   #5
ec1990
Drives: 2012 AGM SS
Start with clay or vinegar and water, if that doesn't work you have water etching which is going to be nigh impossible to remove by hand. If that happens, look into getting a machine polishing kit which will not only remove water spots but swirls and scratches you may have in your paint.
ec1990 is offline   Reply With Quote
Old 05-05-2013, 05:39 AM   #6
Bamaguy
Drives: 2011 Camaro 2SS
Happened to me three weeks ago. Ended up doing a two and three stage correction on the entire car. May want to look into something like Chemical Guys Water Spot Remover.
Bamaguy is offline   Reply With Quote
Old 05-05-2013, 06:48 AM   #7
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
Originally Posted by tonyko1 View Post
Hello all:
Thanks.
My IBM seems hyper-affected by this too.
I find that Meguiar's Ultimate Quik Wax removes 95% of them. Some of them I do need to get a terrycloth bonnet and hand-buff off using a swirl remover and gentle manual buffing though
ChrisBlair is offline   Reply With Quote
Old 05-05-2013, 06:51 AM   #8
jd10013
Drives: 2012 camaro
Meguiar's ultimate compound and a cloth work pretty good too.
jd10013 is offline   Reply With Quote
Old 05-05-2013, 06:58 AM   #9
warren3537
warren3537's Avatar
Drives: 2017 Red Hot 1SS
I use Ammonia free glass cleaner and a micro fiber towel and they come right off without scratching anything, then I follow up with the machine then sealant.
warren3537 is offline   Reply With Quote
Old 05-05-2013, 07:08 AM   #10
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Use a micro fiber towel to dry right after washing and you shouldn't have water spots. A good detail spray and micro fiber should take most off.
I am from Oregon and know how much it rains and makes spots if there is any dust on the car. Usually this time of year it doesn't stop raining long enough to let spots form.
I have a couple boxes full of Adam's products if I could just get a couple days off work and good weather at the same time to wash, clay, seal, glaze and wax, then admire the shine!
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 05-05-2013, 09:22 AM   #11
rich3fan
What's this button do?
rich3fan's Avatar
Drives: 2013 SIM 2SS/RS L99
http://www.adamspolishes.com/t-videos.aspx
Just pick the applicable video and you'll have your answers.
rich3fan is offline   Reply With Quote
Old 05-05-2013, 10:50 AM   #12
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
My buddy owns a boat shop and he gave me 2 bottles of this stuff called "Hot Sauce" the other day. It's a water spot remover, detail spray and sealer all in one. Works fantastic!
Smells like vinegar, but it takes off spots and leaves a great shine.
http://boatbling.net/products/boat-b...uct/hot-sauce/
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 05-05-2013, 01:47 PM   #13
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
CG Hybrid V7 Detail/sealant does the same thing, for less $$, is designed for vehicle paint, and smells like tangerines.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-05-2013, 01:54 PM   #14
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
It will take off light water spots the same as any other detail spray, but will do nothing for the stubborn ones that are being discussed in this thread. I'm guessing that "Hot Sauce" stuff has some vinegar in it, which is what would help with stubborn water spots.
[B]
