05-05-2013, 03:49 PM | #1 |
Drives: 2013 2SS Convertible, LS3 Join Date: Mar 2013
Rear end break away
2013 SS. The rear end seems to break away more often than I was expecting. {Was previously driving a G8, the best handling car I have ever owned.} Recovers quickly and perfectly, however.
Has this been anyone else's observation? |
05-05-2013, 04:34 PM | #2 |
Common side effect of soft subframe bushings. Time for an upgrade!
05-09-2013, 02:55 PM | #3 | |
Drives: Camaro Justice Join Date: Jun 2007
Oldag, Rear end step out is common with the Camaro. It is so common we sometimes forget to check alignment. If the rear toe is not set correctly the rear end step out is dramatically increased. Find a quality alignment shop and have them align to these exact specs. Front Toe 0.00 Front Camber -1.00 Rear Toe IN 0.10 Rear Total Toe 0.20 Rear Camber -.050 Your steering will feel more on center. Hard acceleration will be improved along with turn in and a slight reduction in understeer. |
05-10-2013, 09:27 AM | #4 |
Thanks
05-10-2013, 09:37 AM | #5 |
Drives: pleather and Chiclets Join Date: Mar 2012
as stated above the booty on my car liked to move around till i got bushings and an alignment change. Alignment helped a surprisingly amount and the bushings just made it perfectly predictable and stable...i am auto so standard might have different results.
05-10-2013, 05:13 PM | #6 |
They are the same. You nailed it.
05-10-2013, 05:31 PM | #7 |
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6 Join Date: Dec 2011
Exactly what I'm doing with mine for the same reason. Pfadt solid subframe bushings + rear trailing arms & toe rods.
05-10-2013, 05:42 PM | #8 | |
36.58625, -121.7568
05-10-2013, 06:09 PM | #9 |
Drives: 2011 2SS/RS 2004 GTO Join Date: Sep 2012
Pete, is that rear camber a typo?
2011 2SS/RS - Kooks Headers, HFCs, Corsa exhaust, Magnacharged, Cold Air Inductions CAI, tuned by JRE
05-10-2013, 11:46 PM | #10 |
05-24-2013, 10:28 AM | #11 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
There are a few things you can do to help that, but they are hitting it right on the head. Give us a ring or shoot a PM if you have any more questions!
03-21-2014, 05:54 AM | #12 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Getting tires mounted at tire kingdom this weekend lol. I have a friend that works there so I'm going to see if he can do an alignment to those specs. Thanks for the info guys.
03-21-2014, 06:38 AM | #13 |
03-21-2014, 09:14 AM | #14 |
how different are those specs from the OE specs? mne is currently aligned to factory specs and yea...i can step the ass out at will. wouldnt mind it being a little more planted, although that is fun from time to time haha.
Thread Tools | |
