Gen5DIY
Old 05-06-2013, 08:25 AM   #1
DEANGE2001
DEANGE2001's Avatar
Drives: 2010 2ss LSR CAI, Borla S axle back
Hurst Short Throw Shifter
Hey guys,
For anyone who has or who has installed a Hurst ST shifter:
When I have the car running in 5th or 6th gear, i get a sound that appears to be coming from the shifter/transmission area that almost sounds like rubbing or virbration.
It only seems to be in those gears and I am not sure if this is normal or if i installed things wrong (not sure if that is possible as it all seems to be working fine and had no real issues with the install (I thought putting the boot back on was pretty easy).
Any feedback is appreciated.
Thanks.
DEANGE2001 is offline   Reply With Quote
Old 05-06-2013, 08:51 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Its a 2pc shifter, that makes it have a small vibration in the shifter, try holding the point where they mate ( the 2 bolts) and if the sound goes a way your good, you can add some sound dentener there too.
Old 05-06-2013, 09:40 AM   #3
DEANGE2001
DEANGE2001's Avatar
When I am driving, and while it is in either 5th or 6th gear I can push on the shifter to the right slightly and the sounds seems to reduce quite a bit...
I was thinking of using some kind of sound reducing material at the mating point and see what that does (cant hurt I guess).
Hopefully that works.
Old 05-06-2013, 09:44 AM   #4
2SSRS@Gen5diy
It will help some but not remove it all.
Old 05-06-2013, 09:50 AM   #5
AKA-22
AKA-22's Avatar
Drives: ELLE-1
sub
AKA-22 is offline   Reply With Quote
Old 06-17-2013, 03:12 PM   #6
meSSohappy
meSSohappy's Avatar
Drives: Waiting for 2018 ZL1 A10
I recently installed this shifter amd the kit came with a dampening materila(rubber) that I installed bx the two pieces.....no vibrations or soumd at all.
1st - 2011 2ssrs IOM vert 6spd
2nd - 2015 ZL1 white vert auto
next- 2018 ZL1 hyper blue coupe A10
meSSohappy is offline   Reply With Quote
