BORLA
Old 05-06-2013, 11:00 AM   #1
Bryaniskoo
Drives: 2010 RS
Straight Pipe
A friend of mine has an exhaust shop. We decided to straight pipe my Camaro and see what it does. It sounds like a really loud crotch rocket. Fun for a couple days I guess. Huge loss of torque and gas mileage but we expected that.
My oil pressure seems to be jumping around all crazy. The car is not behaving much different them from when it had 40 series mufflers on it though. Is this something to be worried about or is it just from loss of back pressure?
Bryaniskoo is offline   Reply With Quote
Old 05-07-2013, 08:23 AM   #2
Vgav1221
Vgav1221's Avatar
Drives: 2011 2LT/RS/M6 Black w/ Orange Guts
its just not good for your engine when u **** around with solely str8 pipes. the back pressure is a biggie. You never wanna really lose power on a car, it really messes with the computers. gaining power is always okay because your trannys ment to handle up to a certain amount.
If something ever made me lose horsepower on a stock car or even torque, i wouldnt bother doing it.
Get some baffles, get that back pressure back in there
Vgav1221 is offline   Reply With Quote
Old 05-07-2013, 08:34 AM   #3
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS
Straight pipes DONT do anything to the performance of your car. Back pressure dosent exist
colingordon is offline   Reply With Quote
Old 05-07-2013, 09:55 AM   #4
Niko
Treasure Coast Camaro 5
Niko's Avatar
Drives: Black Camaro LFX
I know for motorcycles back pressure is used for carbs. But because it is a F/I engine back pressure isn't needed for engine cycle. That's my 2cents
Niko is offline   Reply With Quote
Old 05-07-2013, 10:27 AM   #5
Belam
Drives: Yellow 2SS camaro
I used to have straight pipes before and trust me it was like a train ,lost power and terrible noise .I had to pay for the shop to put on some flowmaster in just 2 days of having straight pipes .
Belam is offline   Reply With Quote
Old 05-07-2013, 10:41 AM   #6
TheShowStopperLFX
TheShowStopperLFX's Avatar
Drives: 2012 LFX
Get the MangaFlow X-pipe Muffler. or any X pipe Muffler it quite it down and sounds nice. i have it don't to my car.
http://www.apex-speed.com/magnaflow-...ipe-11386.html
TheShowStopperLFX is offline   Reply With Quote
Old 05-07-2013, 10:44 AM   #7
Vgav1221
Vgav1221's Avatar
That is completly false.
Str8 pipes make you lose power. there is such a thing as back pressure.
Dynos prove it already to be true. do
Old 05-07-2013, 11:18 AM   #8
Niko
Niko's Avatar
The member Coloeb wrote this in another topic
Backpressure: The myth and why it's wrong.
I. Introduction
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Engines need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
II. Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
III. Backpressure and velocity
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
IV. So how did this myth come to be?
I often wonder how the myth "Engines need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
V. So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
Old 05-07-2013, 11:32 AM   #9
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
To summarize, it's scavenging, not back pressure we're referring to here.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-07-2013, 03:59 PM   #10
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 Summit White 2LT/RS
I want to know what Coloeb said back pressure didn't exist and then goes on to prove its existence while giving it a different name.
DSX_Camaro is offline   Reply With Quote
Old 05-07-2013, 04:38 PM   #11
KMPrenger
KMPrenger's Avatar
Backpressure is the wrong term. Velocity is the right term.
Old 05-07-2013, 06:53 PM   #12
Niko
Niko's Avatar
He is meaning how back pressure is thought to be by many people does not exist. And velocity is the correct term.
Old 05-07-2013, 10:59 PM   #13
TheShowStopperLFX
Drives: 2012 LFX
this is what it sounds like.
Old 05-10-2013, 10:23 AM   #14
Vgav1221
Vgav1221's Avatar
Back pressure is needed for engines nuff said.
Go do research on something other then the forum, but wait a minute, everything you read on a forum must be true........................
