B&M Racing
Old 05-06-2013, 11:18 AM   #1
8863
Drives: 2013 Camaro 2LT RS
engine oil pressure
I was wondering what the oil pressure numbers should be on the LFX engine. I just purchased a new 2013 2LT with this engine and noticed the oil pressure jumps up to 70 psi when cold, practically pegging the needle. Once it starts to warm up it drops to around 30-35 psi. Is this the norm?
8863 is offline   Reply With Quote
Old 05-06-2013, 11:29 AM   #2
SC2150
That is a little low.....at cruise? At idle it is fine, but as soon as you are up in RPM's it should be above 50 to maintain tension on the chains.
Old 05-06-2013, 11:45 AM   #3
8863
Maybe I should rephrase my post. These oil pressure readings I'm talking about are at idle. I haven't owned the car long enough to be able to quickly read the oil pressure gauge while driving since it is down low on the console.
Old 05-06-2013, 09:27 PM   #4
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
What you are describing is normal for at-idle readings on the LFX.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 05-06-2013, 10:30 PM   #5
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
When I accelerate it will peg the needle (70psi I think). Cruise at around 45 mph it is right in the middle (30 or 35 psi).
BaylorCamaro is offline   Reply With Quote
