Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 05-06-2013, 08:43 PM   #1
DAVID2010SS
DAVID2010SS's Avatar
Drives: 2010 SS 6 SPEED
tach
I have a 1979 z-28 with 15,000 miles and the tach quit.Is there a fuse or after 34 years did it let me down. help
David T
DAVID2010SS is offline   Reply With Quote
Old 05-08-2013, 12:10 AM   #2
flyingskibiker
flyingskibiker's Avatar
Drives: Cars, Trucks, Bikes, ORVs, Planes
Send a message via Yahoo to flyingskibiker
I only know my '68 to that level of detail. It has a Pink power wire to the cluster. It powers the tach (or fuel gauge), Fuel warning (or GEN light), and e-brake (and Oil light. It depends on gauges installed). So, maybe there is one for yours? It is the Gauges fuse in '68s.
1968 SS w/ 1966 427/425 Sequoia Green w/ Bumble Bee stripe. Always working on it...
Drooling over the ZL1s. It will be my next car if I can manage to pull it off...
flyingskibiker is offline   Reply With Quote
Old 05-12-2013, 11:14 AM   #3
David79z28
David79z28's Avatar
Drives: 79Z28 and 2010 2SS/RS
The only fuse I see on the wiring diagrams effects all gauges.
Have you checked the connection to the distributor? That's where my problem was the last time mine stopped working.
David79z28 is offline   Reply With Quote
Old 05-13-2013, 01:23 AM   #4
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
The distribution is where I would look but it could also be a ground or connection on the gauge cluster circuit board that finally cracked and created an open.
- Buttons and Skulls -
miss my annimated signature.
itsadryheat79 is offline   Reply With Quote
Old 05-14-2013, 03:43 AM   #5
flyingskibiker
Man, they still have circuit "boards" in '79??? Crud!
Old 09-30-2013, 10:33 PM   #6
DAVID2010SS
tach
finally found a tach. 30 bucks on ebay and like new. Now back to 100%.After 34 years it still like the day I pick it up.
David T
