05-06-2013, 09:18 PM | #1 |
need help installing amp and sub to BA
hello everyone im new to this forum i been trying to figure out how to wire my amp and sub to the BA amp
i read a post from here and i was going to do what it said but when i read more threw the post apparently he was wrong on the install i have the amp sub the wirng kit wires and rca output adapter i know this requires splicing and all that but im used to it so please help and explain what i need to splice or do :( |
05-07-2013, 05:12 PM | #2 |
Drives: 2018 1LE Join Date: Feb 2013
You are going to need a high low adapter this turns the low level single come from the radio in to RCA out put . Low level wires coming from oem radio to amp. And the amp kit is all you need set aftermarket amp crossover 200hz Some aftermarket amps have high low inputs built if I was you I would grab the wires at the amp find the rear set and splice into them that why if you ever had to much bass you can fad the radio forward ( like you can ever have to much bass ) also you are going to need to tell the amp to turn on there should be a black 44 pin harness at the oem amp pin 43 should be a Wite tap that for amp turn on. You may get a loud pop when amp turns. Best of luck
