Old 05-07-2013, 12:20 AM   #1
infernostripes!
Drives: 2010 1ssrs
TC for Comp cam 231/247 617/624
Hey guys, could anyone tell me what size of TC I should get with a Comp cam 231/247 617/624? I don't really know much about TCs
Also what is you opinion on buying a fairly used TC?
Thanks!
infernostripes! is offline   Reply With Quote
Old 05-07-2013, 12:45 AM   #2
texas_boss
texas_boss's Avatar
Drives: 2010 RS/2SS
3000-3200 is what I have with same cam.....
MODS:
COMP CAMS 231/247 113LS, LG LTs and 3" exhaust, Pfadt springs and sways, BMR TA's and bushings, Elite catch can, Holley Coil covers, heater hose re-route and fuel rail swap.....
texas_boss is offline   Reply With Quote
Old 05-07-2013, 03:13 AM   #3
infernostripes!
Drives: 2010 1ssrs
Did ARD do the work on your car? haha
Old 05-07-2013, 09:06 AM   #4
Alvin@PCMofNC
Drives: 2010 IOM RSS
I would say at least a 3200.
Alvin@PCMofNC is offline   Reply With Quote
Old 05-07-2013, 09:11 AM   #5
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
3200 Minimum. Id go with a 3600-4000 if you are going to race the car at the track. The 3200 will not give you the 60' times you are looking for. I run a Circle D 4000 in my daily driver.
Regardless which converter you choose, be sure to install an external trans cooler.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 05-07-2013, 09:43 AM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It's going to depend on how you use your car. If it's a DD with occasional drag strip appearances, i'd look to something that is very street friendly. Also know that the same stall TC from different vendors can be very different. Talk to shops that know about them and try to drive a few before you make up your mind.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-07-2013, 09:45 AM   #7
SC2150
3400-3600 if going with our triple disc. Takes 1-2 days to build it to match your goals and use. You wont regret it.
Drive like stock until you put your foot in it and allows lumpy cam idle.
Old 05-07-2013, 10:23 AM   #8
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Also need to know that a 3x00 RPM stall from brand A converter company is not the same as from brand B. Its always good to call the converter company that you are buying from and tell them your mods, goals and driving wants so they can give you a recommendation. I would recommend FTI or Circle D.
Old 05-07-2013, 07:00 PM   #9
infernostripes!
Drives: 2010 1ssrs
Seems like TCs are more of custom product. Would going used be bad then? I figured i could save about $400-$500 and get a fairly used TC. Kind of working on a budget. I know I could wait till I got the money but its more of id rather spend 3500 on this project then 4000.
Old 05-07-2013, 07:24 PM   #10
VADER SS L99
If you buy a used one I would get a FTI or Circle D and then send it back to the mfg to have it checked out and restalled for your mods. This will make it like new without the new price tag. It would also mean you could choose whatever used stall because you will be restalling it anyway.
Old 05-07-2013, 08:21 PM   #11
JEFF75645
Drives: his wife crazy buying mods
^^^ I bought a used Circle D and sent it back to Circle D and Chris fixed me up. He got with the shop I use and they opened it up and pretty much completely rebuilt it to spec.
I paid $500 for a Circle D multi disk stall and tci flex plate. It cost $325 to rebuild to spec. So $825 for spec'd stall and flex plate.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 05-07-2013, 08:27 PM   #12
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I agree 3200 would be bare minimum. I personally would run a 3200 on a stock cam lol.
Old 05-08-2013, 10:27 AM   #13
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Anyone have a vid of this cam, has to sound pretty sick with that big of a split.
@ OP, if you can try to drive a car with a converter if you've never had a bigger aftermarket one, to see if you like it. A Circle D 3200 can drive very nice, and you'll hardly notice it after a week. Their 3600 would do even better, but you are making a big move from the stock one which is like a 1600/1700.
Ryan, is the one in your car ultimately a 4000, Jim @ Speed thought it might even be a bit bigger (though it would have been looser with stock gearing).
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-08-2013, 10:43 AM   #14
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
We have used that cam before in LS7's. I would suggest a Yank 3400 for that camshaft or a Vig3200. Feel free to give us a call and I can help answer any questions you may have.
Shawn
Lethal Racing is offline   Reply With Quote
