Old 05-07-2013, 12:22 PM   #1
HBMike
HBMike's Avatar
Drives: 2010 Synergy Green HBR
Hillbank Synergy Green
Finally got around to digging up all the photos. Apparently people wanted to see my build so here we go!
I regularly road race the camaro along with taking to pretty much every car show down here in southern California. Below is a list of everything that I've done to the car.
Appearance
ZL1 front fascia, lighting, lower grille
Trucarbon Carbon fiber hood
CDC Havoc Side rockers, Spoiler, and Rear Diffuser
Anzo Projector headlights and led taillights
TSW Rotorary forged Rims
Blackout rear deck
Carbon fiber roof and trunk appliqué
Green / black Leather seating
Black Leather steering wheel
Carbon fiber interior trim and consol
Brakes
Wilwood 6 piston calipers front with 14" cross drilled and slotted rotors
Wilwood 4 piston calipers rear with 14" cross drilled and slotted rotors
Stainless steel Braided brake lines
Suspension
KW variant 3 + coil-overs, adjustable ride height, dampening and rebound
Hotchkis front sway bar and end links
Hotchkis rear sway bar and end links
Whiteline bushings:
Cradle, differential, steering rack, radius rod, toe arm, trailing arm, control arm, upper control arm
Hotchkis cradle brace and safety catch
Hotchkis strut tower brace
Power/performance
IPF centrifugal supercharger 435 HP
Mishimoto intercooler and catch can
Airaid air filter
Magnaflow full exhaust
Power steering cooler
Upgraded Kevlar composite bronze clutch disc
American Racing long tube headers
Misc
Green Led interior and trunk lighting
Green Retro 70's shift knob
Everything we've done here at Hillbank Motorsports here in Irvine CA
Wilwood 6 Pistons -Magnaflow X-Cat back - CDC Havoc Styling - TSW Wheels - Roadwire Custom Green Leather Interior - Hotchkis Race Suspension - Whiteline Flatout - KW V3 Suspension - 3M Wraps - Toyo Tires - IPF Supercharger - Vortech V3 - Airaid Filters
HBMike is offline   Reply With Quote
Old 05-07-2013, 12:29 PM   #2
Demon Z/28
Scarecrow
Demon Z/28's Avatar
Drives: like a granny
See it all the time in irvine ! Sweet car !
The Rooster - 2015 Z/28
The Scarecrow -2014 1LE SOLD -
Demon Z/28 is offline   Reply With Quote
Old 05-07-2013, 12:36 PM   #3
laditee
laditee's Avatar
Drives: 2010 Camaro 2SS
Wooow very nice.
laditee is offline   Reply With Quote
Old 05-07-2013, 01:03 PM   #4
SlyJester7
SoCal HT5 *COTW 8/26/13*
SlyJester7's Avatar
Drives: 2013 SS/RS LS3
WOW! looks great!
SlyJester7 is offline   Reply With Quote
Old 05-10-2013, 06:29 AM   #5
SilverSlayer-SS
SoCal HT5
SilverSlayer-SS's Avatar
Drives: 2010 SS , 2014 SS
AMAZING !
SilverSlayer-SS is offline   Reply With Quote
Old 05-10-2013, 07:19 AM   #6
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
woooow awesome car and great build
Old 05-10-2013, 07:33 AM   #7
sycraft
COTW 5/06/2013
sycraft's Avatar
Would love to see the steering cooler, and how do you keep your trans temps in check on the track, mine was over 300 degrees on 1 25 minute outing. thanks to the syncromesh for keeping the trans safe, immediatly changed the fluid out after that day.
Old 05-10-2013, 07:46 AM   #8
wadew2lt
U.S. Army Veteran
wadew2lt's Avatar
Drives: 2LT/RS SGM M6 Polished 20's
Let me know when you happen by PA. I'll keep mine in the garage!
WOW!!!
wadew2lt is offline   Reply With Quote
Old 05-10-2013, 11:12 AM   #9
HBMike
HBMike's Avatar
I'll snap a photo of the power steering cooler for you this weekend; its a derale.
As for Trans temps, I run a plastic sign board material self made belly pan that runs the air down the tunnel to the trans instead of just down and lifting the car. I suppose you could use a ZL1 belly pan, but its more entertaining saying you made this crudely cut plastic pan that does the same thing? haha
Old 05-17-2013, 06:56 PM   #10
HBMike
HBMike's Avatar
A little description of what you're looking at. This is a photo through the lower grille because I'm too lazy to take anything off. The cooler sits behind my intercooler at an angle. The plastic ducts air to the radiator and i just secured it to the lower ducting tray.
Old 05-29-2013, 03:51 PM   #11
HBMike
HBMike's Avatar
Race buckets... saving over 40 lbs a side.
Old 05-29-2013, 04:11 PM   #12
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Amazing Camaro!!
JT
Team STILLEN is offline   Reply With Quote
Old 05-30-2013, 06:20 PM   #13
HBMike
HBMike's Avatar
Thanks for the kind words
Old 05-30-2013, 07:18 PM   #14
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
Ir0nM4n is offline   Reply With Quote
