BORLA
Old 05-07-2013, 03:21 PM   #1
theham3
theham3's Avatar
Drives: 2011 VR RS/2LT K@N CNT Cat Back
ss spring, struts, and sway bars
Need some help. Will these fit on a v6, and will there be a benefit? Thanks
theham3 is offline   Reply With Quote
Old 05-07-2013, 03:26 PM   #2
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
yes they will fit there will be some benefit... I have all my original SS suspension pieces for sale. Toe rods, Sways, end links, springs, shocks, Rear lower Control arms etc...
RaiderSS is offline   Reply With Quote
Old 05-07-2013, 03:32 PM   #3
theham3
theham3's Avatar
Thank you. PM me the price and condition.
Old 05-07-2013, 09:06 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Wouldnt be to much of a improvement going from fe2 (v6) to fe3 (2010-2011 v8) what you should be looking for is fe4 and up swap if your wanting to go factory upgrades
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 05-12-2013, 09:23 PM   #5
VEESIKS
formerly 2011Camaro
Drives: 2011 Camaro LS IBM M6
I thought I read somewhere that swapping the V6 and SS springs would offer about 1/2" drop. Feel free to chime in if anyone knows true or false
Born on the Island and raised in the sand.
Semper Fidelis
VEESIKS is offline   Reply With Quote
Old 05-12-2013, 09:44 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
True.
Click to view my build thread
Old 05-13-2013, 09:56 AM   #7
VEESIKS
formerly 2011Camaro
Is it necessary to change struts/shocks too. I got a hook on a set of springs from a local member already. Don't want to take the car apart twice if I can help it
Semper Fidelis
Old 05-13-2013, 11:48 AM   #8
ICTsccaCamaro
ITCRNRS
You can change springs only if you want ss springs will fit v6 struts just fine
Old 05-13-2013, 08:26 PM   #9
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
The springs will definitely change your ride height. As others have said, go for the 2012-2013 SS suspension for more of an upgrade
Old 05-13-2013, 11:32 PM   #10
RaiderSS
RaiderSS's Avatar
PM Sent...
Old 05-14-2013, 01:28 PM   #11
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
You can use your stock dampers, however it would be optimal to use the shocks/struts of an SS as well as they are dialed into the spring rates of the spring. It's not going to hurt anything, but the ride will be more bounce on the V6 dampers.
Best regards,
Tyler
888-308-6007
Old 05-14-2013, 07:55 PM   #12
theham3
theham3's Avatar
Thanks to everyone for the info.
Old 05-26-2013, 12:23 AM   #13
VEESIKS
formerly 2011Camaro
Installed a full FE3 suspension yesterday. I am liking it so far, can tell a difference with the stiffer springs and bigger sways. Unfortunately I snapped the threads on the driver strut by over tighening the top most nut so as of now i have FE2 front struts with FE3 springs and full FE3 set up on back. To anyone doing the swap be careful not to over torque the nuts on the front struts. The threads are designed to break away the top inch so if they fail it will still retain the spring with the bottom nut. Anyone have some FE3 front struts laying around they want to donate?
Semper Fidelis
