Gen5DIY
Old 05-07-2013, 04:37 PM   #1
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
Need advise on strip washing
I have been neglecting my car a bit and need to do a full detail. When I purchased it I did not use iron x prior to clay and I want to do this this time around. So how would you go about removing all the wax/glaze and sealant that you put down on the car?
Just apc in your wash media and foam gun with a traditional two bucket wash or do you have other suggestions.
After I strip the car and use iron x on the paint I want to clay and wax it. But I would like to do this extremely well so any thoughts and processes that work for you pros would be helpful.
Laus Deo
charlietuna is offline   Reply With Quote
Old 05-07-2013, 04:58 PM   #2
trm2
Drives: '13 Volt & '84 Vette
APC in the water will do the trick. If you want to do a panel at a time, you can use Isopropyl Alcohol - diluted in a spray bottle.
trm2 is offline   Reply With Quote
Old 05-07-2013, 06:23 PM   #3
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
APC in your car wash solution. I usually do about 3oz to the 5 gallon mixture + whatever dilution your car wash soap usually is. Between this and clay most everything is stripped.
Or as trm2 mentioned you can strip 1 panel at a time with isopropyl alcohol and a microfiber towel. Either method is acceptable.
Old 05-07-2013, 06:39 PM   #4
ec1990
Drives: 2012 AGM SS
You can also pick up some CarPro Eraser
ec1990 is offline   Reply With Quote
Old 05-08-2013, 06:32 PM   #5
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
Dylan with the isopropyl alcohol do you dilute it with water and if so what is the ratio?
redirish is offline   Reply With Quote
Old 05-08-2013, 06:56 PM   #6
ec1990
Drives: 2012 AGM SS
Personally I'd use no more than a 10-15% solution. This ration will depend on the IPA you pick up. You can find usually anywhere from 30%-100%. If its 100 then use a 1-2oz of IPA for every 10 oz of liquid ratio.
Check this post out.
Old 05-09-2013, 07:07 PM   #7
redirish
redirish's Avatar
ec thanks for the good information
Old 05-09-2013, 07:23 PM   #8
charlietuna
Drives: 2013 ZL1
thanks to all that responded. I did a dawn dish soap and apc foam bath. Then a dawn and apc two bucket wash followed by some Iron-cut and another foam blast and wash.
I think i lowered the level of lake michigan today with all the rinsing but from what ive read you dont want to leave any iron cut anywhere.....
im on to claying i will post pics soon
Laus Deo
Old 05-09-2013, 10:11 PM   #9
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS, 2011 2SS/RS
WiSSDiver is offline   Reply With Quote
