Old 05-07-2013, 05:08 PM   #1
Uribees
Drives: Camaro 2010
P2099 Fault Code
Hey guys,
I received a fault code P2099 (Powertrain Post Catalyst Fuel Trim System Too Rich bank2) on my OBDII. I had this fault a few months back and cleared it and everything was good for a while. About a week ago it came back (along with the check engine light). The check engine light will be on sometimes and other times it will be off (without me clearing the fault). Any advice or help would be much appreciated.
Uribees is offline   Reply With Quote
Old 08-28-2014, 11:46 AM   #2
Uribees
Drives: Camaro 2010
BUMP?
Old 08-28-2014, 01:11 PM   #3
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Everything stock?
hunter1660 is offline   Reply With Quote
Old 06-10-2015, 04:53 PM   #4
Uribees
Drives: Camaro 2010
Yes everything is stock. Any ideas?
Old 06-10-2015, 04:56 PM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Umm, how about a bad sensor?
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-10-2015, 05:35 PM   #6
Uribees
Drives: Camaro 2010
Any idea which sensor to purchase? I see upstream/downstream and left/right/center.
Old 06-10-2015, 05:45 PM   #7
1KillerSS
1KillerSS's Avatar
May not be a bad sensor after all.
P2099 Post catalyst fuel system trim high limit bank 2
Post cat is the sensor after the cat.
Check this thread out.
http://www.camaro5.com/forums/showthread.php?t=102750
Build thread
Old 06-10-2015, 05:51 PM   #8
1KillerSS
1KillerSS's Avatar
Could also be a bad cat. If you were tuned, those codes would/should be turned off. Something is causing your system to run too rich, possible the cat is not doing its job, or a faulty sensor.
Build thread
