Cold Air Inductions
Old 05-08-2013, 05:06 AM   #1
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
1LE MPG......
Hey Guys,
im just curious to see what everyone is getting for average mpg. i know its different based on the type of driving, location, style etc....i know the gear ratio is more agressive but i averaged right around 19.5 in my 2012 ss
i have a hard time getting over 16 mpg in my i drive the 2 cars exactly the same i just didnt expect that big of a change. Trust me i could care less if it got 5 i didnt by it to be economical or fuel effiecent but i think it would be cool to see everyones numbers just to compare and if you had another camaro before the 1le what are your opinions ?
stats 15.8 mpg average type of driving is spirited mainly on highway and back roads 5100 miles on the car now
coreyaustin17 is offline   Reply With Quote
Old 05-08-2013, 06:55 AM   #2
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
OnStar remote link says I'm at 17, but I just did 400 miles of highway driving. I think I was 15-16 before that with mostly city driving. Both are better than my Ram, so no complaints!
bluBlud is offline   Reply With Quote
Old 05-08-2013, 07:16 AM   #3
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
15 but I have a heavy foot.
BigBlock69RS is offline   Reply With Quote
Old 05-08-2013, 09:38 AM   #4
ghostrider77
Drives: 2013 Black Camaro 2SS/RS 1LE
12.5
ghostrider77 is offline   Reply With Quote
Old 05-08-2013, 10:23 AM   #5
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Anything above 14.5 with just stop and go driving and you should be in a honda. :-)
MY 2011 LS3 with headers intake and a tune got about the same. But it was also convertible and had 21s.
tramtwo is offline   Reply With Quote
Old 05-08-2013, 12:58 PM   #6
1Slow6.2
1Slow6.2's Avatar
Drives: 2013 1LE camaro
Averaging 16 according to my onstar app. I have exactly 500mi on mine
Sent from my hip pocket.. While slapping 5th.. As your reading my plate
1Slow6.2 is offline   Reply With Quote
Old 05-08-2013, 04:26 PM   #7
charlie46
Drives: 2013 camaro 1le
13 mpg
charlie46 is offline   Reply With Quote
Old 05-08-2013, 04:32 PM   #8
Tara Martin
Loves Camaros
Tara Martin's Avatar
Drives: Red '79 Z28, '17 HBM M6 ZL-1!
Onstar says 17 mpg lifetime average. Current tankfull is almost 19 mpg. Mostly during the week, I drive to and from work which is 35% highway and 65 city. If there's a Mustang or a Challenger around, the mileage is much worse...not sure why...
Okay, ok; I know where my Camaro is now! In my driveway!
Tara Martin is offline   Reply With Quote
Old 05-08-2013, 04:59 PM   #9
Lickwid Apex
OD
Drives: '16 HB 2SS A8
Send a message via Yahoo to Lickwid Apex
19.3 with to/from work so far. I've somehow managed to resist heavy foot driving all the time. This 'sex-on-wheels' gets better gas mileage than my old Armada. And lets be honest, I didn't pick either vehicle for its MPG. I just like turning heads. That's easier to do if I'm not smokin the tires.
Lickwid Apex is offline   Reply With Quote
Old 05-08-2013, 05:11 PM   #10
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
If you look at the gear ratios between a regular ss and a 1LE, in 6th gear you are running a slightly lower rpm than a ss. I thought it would be the other way around, but due do the difference in the tranny ratios it should actually be a tick better on gas.
MM6 w/ 3.91
1st gear ratio: 2.66 10.42
2nd gear ratio: 1.78 6.97
3rd gear ratio: 1.30 5.09
4th gear ratio: 1.00 3.91
5th gear ratio: 0.74 2.90
6th gear ratio: 0.50 1.96
M10 w/ 3.45
1st gear ratio: 3.01 10.38
2nd gear ratio: 2.07 7.14
3rd gear ratio: 1.43 4.93
4th gear ratio: 1.00 3.45
5th gear ratio: 0.84 2.90
6th gear ratio: 0.57 1.97
CamaroTom is offline   Reply With Quote
Old 05-08-2013, 05:12 PM   #11
Bauer2
Bauer2's Avatar
Drives: 2013 2SS/1LE and 2009 R1
Mine says 16 after almost 700 miles but thats almost all city driving and I like the exhaust note so I'm sure that doesn't help.
Bauer2 is offline   Reply With Quote
Old 05-08-2013, 05:13 PM   #12
Bauer2
Bauer2's Avatar
On the highway it probably is a tad bit better but in the city not so much.
Old 05-08-2013, 06:35 PM   #13
Crand
Crand's Avatar
Drives: away the ladies :(
Send a message via AIM to Crand
19.5
Crand is offline   Reply With Quote
Old 05-08-2013, 08:04 PM   #14
Anderson1LE
Drives: 2013 Summit White 1SS 1LE
Typically around town I average 15 to 18 mpg just depending on how hard I drive, but I went to visit my mom last weekend and I reset my mpg avg before I left and it did not drop below 25 on the highway cruising at 75, 2k miles at the time. I was very pleased with this as I figured I would be getting about 22-23 but I'm not worried about mpg, just thought I would share for the OP's sake.
Anderson1LE is offline   Reply With Quote
