JDP Motorsports
Old 05-08-2013, 09:38 AM   #1
Greenlantern99
Drives: '99 S10 ZR2/'13 1LT RS
Warning: nitrous noob with lots of questions.
I am a soon-to-be LFX A6 owner and I will be spraying it with the Ny-Trex Triple system. I understand just about all there is to know about nitrous except:
1.) How should I handle shifting with the WOT switch? Don't you have to let off the juice when you shift? And if so, how? Do you cut the arming switch off since you shouldn't let off the gas for shifting?
2.) Should I go to a colder plug with 100 shot? If so, what is the recommended plug? Will the colder plugs affect fuel milage or performance when I am not spraying? Keep in mind this will be a daily driver.
3.) Recommend fuel octane? Should my tank only contain the higher octane fuel when I spray or can it be mixed?
4.) Can I route the bottle pressure guage to driver's view? Reccomended bottle pressure?
Any help would be appreciated, thanks for looking.
Greenlantern99 is offline   Reply With Quote
Old 05-08-2013, 09:41 AM   #2
SgtPickles69
Team LFX
SgtPickles69's Avatar
Drives: Fast
SgtPickles69 is offline   Reply With Quote
Old 05-08-2013, 10:16 AM   #3
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
If i'm not mistaken, with an automatic, you are WOT between shifts. the throttle body is open through every gear and between shifts. kind of like power shifting with a manual. so there's no worries about letting off on nitrous between shifts. Just mash the gas and go! ps, window switch is recommended.
NGK LTR7IX -11 6510 iridum is what I believe everyone is running, that has nitrous. me included, when I had it. I had no problems daily driving my car.
I would only put in the highest octane fuel.
never got to this stage before I traded in my car. lol but i'm pretty sure you can do that. good luck!
see red
Old 05-08-2013, 10:25 AM   #4
Greenlantern99
Much appreciated, thanks man
Old 05-08-2013, 10:36 AM   #5
PoorMansCamaro
Drives: Really Slow
no problem, keep us updated on your track days!
Old 05-08-2013, 02:16 PM   #6
john@nitrousoutlet
Drives: Camaro
I wouldn't recommend using the iridium plugs, use a NGK BR7EF for 100 shot.
john@nitrousoutlet is offline   Reply With Quote
Old 05-08-2013, 02:50 PM   #7
PoorMansCamaro
Drives: Really Slow
any particular reason?
Old 05-08-2013, 03:24 PM   #8
429
Drives: 2010 camaro ss
The iridium electrodes are physically very small. Nitrous creates a lot of additional heat that can potentially melt/wear the tiny electrode vs the larger electrode of a copper plug
429 is offline   Reply With Quote
Old 05-09-2013, 07:08 AM   #9
PoorMansCamaro
Drives: Really Slow
that's good to know! I'll have to remember this thread, when i'm ready to buy nitrous.
Old 05-09-2013, 07:44 AM   #10
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
I'm selling the nytrex kit with a heater, opener and controller, pm me for details...
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 05-09-2013, 08:44 AM   #11
LeanPocket
Drives: 2010 2SS
buy a window switch and set it to shut off between shifts points. Otherwise, you can spray between shifts without issue if the tuning is spot on.
ngk br7ef plugs, you wont notice any negative effects.
93 octane with a proper nitrous tune.
yes u can, you have to be creative. 950 psi is optimal
in bold
LeanPocket is offline   Reply With Quote
Old 05-09-2013, 11:44 AM   #12
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Old 05-09-2013, 12:25 PM   #13
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
Only of your wife can get a SC! Lol
2014 Black 2SS/RS 1LE
V6owner is offline   Reply With Quote
Old 05-09-2013, 12:26 PM   #14
PoorMansCamaro
Drives: Really Slow
we would, if we had the money!
