Gen5DIY
Old 05-08-2013, 12:29 PM   #1
azw131
Team LLT
azw131's Avatar
Drives: 2012 WRX (Stage 2)
My ALMOST Money Shift
So as I was nearing my exit on the highway, I pulled to the right lane and get ready to get off. I had to slow down to 45 because I end up behind a slow moving truck right before my exit. I go to downshift from 5th into 4th to get off but what do I get instead... 2nd!. The RPM's only shot up to 5000 or so and I quickly put it into neutral. I was really lucky I was going so slow otherwise I wouldve had a serious problem. Nevertheless, I gave myself quite a scare. I've heard the stories of the damage a money shift can do
azw131 is offline   Reply With Quote
Old 05-08-2013, 01:41 PM   #2
silverz28
Drives: 1996 Camaro Z28, 2012 2SS/RS
Did that a few times when I first got the car. You know right away and all it takes is to push that clutch in.
2012 2SS/RS IOM, LS3, Aftermarket Hurst shifter, IOM interior, Borla "S", 1 7/8 Big Flow headers, ADM Race cold air, BMR 1" lowering springs, SLP Supercharger, Custom Comp Cam, Fore Innovations twin pumps, Flex Fuel Sensor
silverz28 is offline   Reply With Quote
Old 05-08-2013, 02:07 PM   #3
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
45 in 2nd is a big deal really. Now if you were going highway speeds it would have been a different story but a majority of the time the Synchrons will grind and not allow you in the gear before you even were able to release the clutch.
Proud owner of litho #179 Click Picture for Build Thread
Old 05-08-2013, 02:11 PM   #4
13FastBlkSS
Drives: 2013 Camaro 2SS/RS M6
That has happened to me once soon after I bought mine as well... it only takes one time and you will never do it again lol!
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs
Build#24869
13FastBlkSS is offline   Reply With Quote
Old 05-08-2013, 02:13 PM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
It doesn't really happen on a down shift too often, its the 3-4 but hit 3-2 that gets you. Most of the time the syncro's won't even let you in though.
Best regards,
Tyler
888-308-6007
Old 05-11-2013, 03:38 PM   #6
MikeOD
Drives: 2010 M6 2SS
2nd at 45 is fun...not a problem at all...should have just smashed the gas pedal down instead of pushing the clutch in.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 05-29-2013, 09:17 AM   #7
TECADON
TECADON's Avatar
Drives: 2011 Camaro 1SS/RS
Yep it is very fun, mine is always accompanied by wheel-spin so I have to pay attention to road surfaces lol. I was thinking I go from 5 or 4th to 2nd alot in them situations where you are like "ok 4 or 5th is not getting it".
2011 SS/RS Homemade CAI, Doug Thorley Muffler Delete, Burns Stainless X-pipe and Dynomax Race Bullets, 8k HIDS and Fogs with harness, Tuned by Me on HPTuners
Yes its quick...quicker then you think!!!
TECADON is offline   Reply With Quote
Old 05-29-2013, 11:02 AM   #8
crazyduc996
Drives: 2011 Camaro SS convertible
I shift down into second regularly at 35-45mph, when I am nearing a curve, I just blip the throttle and to raise the RPM so that when I do put it into second it doesn't ramp the engine up and starve for oil for a second or two, or for more worse lock the rears going into a curve...
GM Hotcam, JBA shorties mated to JBA cat deletes, Solo Performance cat back with J-pipe, Roto-Fab intake
crazyduc996 is offline   Reply With Quote
Old 05-29-2013, 06:20 PM   #9
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
do you guys get that abs feeling if you going a little to fast ? the brake pedal kind of pushes back a little
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/
HardrockSS is offline   Reply With Quote
Old 05-29-2013, 06:30 PM   #10
CFD
Drives: 2SS/RS L99 BLACK
I've never had that problem, oh, sorry, I have an automatic .
CFD is online now   Reply With Quote
Old 05-29-2013, 06:30 PM   #11
CFD
Forgive me, I couldn't resist. lol
Old 05-29-2013, 06:37 PM   #12
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
^^^This... you're right in the Power range.
