Gen5DIY
Old 05-08-2013, 05:24 PM   #1
h018871
Geoff
h018871's Avatar
Drives: 2013 1LE Blue
1LE quality hold Apr-May 2013
Hello,
I have a 1LE on order and it was due for delivery in mid Apr. The sales guy tells me the issue is a "quality hold" on all 1LE's and ZL-1's due to the rear wheels. he did hint that is wa related to the "rear end", but did not understand what the true issue was.The funny thing is that the 1LE and ZL1 have different wheels. He did not know how long the hold will be, but expect it to not be more than a month.
Do anyone have any other info or rumors?
h018871 is offline   Reply With Quote
Old 05-08-2013, 05:29 PM   #2
MPHS_AGM
MPHS_AGM's Avatar
Drives: 2013 Camaro 2SS/RS/1LE AGM
Welcome to Camaro5!
The 1LE and ZL1 do have the same wheels, the tires are the same make and model, just a different size (285 on 1LE and 305 on ZL1). I haven't heard of any reasons for recent holds though. You may want to post this question on the Ordering/Tracking thread to see if anyone else has any ideas for the hold.
Just to clarify: 1LE and ZL1 have the same wheels (20x10 on front and 20x11 on rear). The tires on the ZL1 are 285/35ZR20 [Front] and 305/35ZR20 [Rear]. The tires on the 1LE are 285/35ZR20 on all four corners.
Current:
2013 AGM 2SS/RS/1LE-NPP
Past:
2002 Z28 Navy Blue A4 [traded]
1996 Camaro V6 Black [traded]
MPHS_AGM is offline   Reply With Quote
Old 05-08-2013, 05:35 PM   #3
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Some one mentioned that the temperature up in Oshawa dropped a bit. And, since the tires are very sensitive to low temps as they tend to crack, it's been speculated that GM doesn't want to move the cars and risk damaging the tires.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 05-08-2013, 05:36 PM   #4
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Welcome.
The reason is unknown and unless your dealer knows someone inside the plant the hold reason is most likely not know by him either.
Search the threads under TPW 4/22 or 4/29 and there is more I do in those threads.
Old 05-08-2013, 05:44 PM   #5
Dropspeed
Dropspeed's Avatar
That was a few weeks ago and te temp is now plenty warn enough to move the cars. Some 1LE that were bayed have been released
Old 05-08-2013, 07:03 PM   #6
GearheadSS
GearheadSS's Avatar
Drives: 1969 Chevelle SS
It's not temperature related. It is a quality hold from what I've heard.
GearheadSS is offline   Reply With Quote
Old 05-08-2013, 11:15 PM   #7
HighMtnSS
HighMtnSS's Avatar
Drives: '13 AGM 2SS/RS 1LE, 1 of 139
Man, I would be a basket case if I had to suffer through these delays..! WTH?
HighMtnSS is offline   Reply With Quote
Old 05-09-2013, 10:41 AM   #8
racerx1214
Drives: 2013 1LE
They might not have the wheels. I know this was a problem in march when I went to order. Might be a supply issue.
racerx1214 is offline   Reply With Quote
Old 05-09-2013, 10:45 AM   #9
GearheadSS
GearheadSS's Avatar
I doubt they would produce the cars if they didn't have the wheels. I've never seen GM send a car down the assembly line without all of the ordered parts. That seems like a clusterf&*% waiting to happen.
Old 05-09-2013, 10:57 AM   #10
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I would have to agree. If it is a wheel issue, I would assume it is a wheel problem or a suspected problem with the wheel that has caused the delay, not a lack of wheels.
gajagfan is offline   Reply With Quote
Old 05-09-2013, 11:06 AM   #11
Overclock
Drives: 2000 Ford Ranger, 2013 AGM 2SS 1LE
Yeah, the cars are being sent out for the hood wrap and stipes, so there is no issue with not having wheels. I highly doubt anyone will hear what the actual hold is about, even after it has been completely lifted.
However, it does seem a few 1LEs have been trickling through, unfortunately not in order of TPW
Overclock is offline   Reply With Quote
Old 05-09-2013, 12:10 PM   #12
cbass
Drives: .
We might find out down the line if it isn't resolved and those parts start failing.
cbass is offline   Reply With Quote
Old 05-09-2013, 12:12 PM   #13
gajagfan
gajagfan's Avatar
As much as the wait sucks, the cars on hold will not leave until the problem is resolved beyond the shadow of a doubt, and that is a good thing!
Old 05-09-2013, 12:33 PM   #14
cbass
Drives: .
Yes it is. I just hope it's fully resolved. I would rather get my car later and right then with issues I have to deal with because then you hope your dealer's service department is competent.
quality hold
