Solo Performance
Old 05-08-2013, 07:00 PM   #1
Stucker152
Drives: 10 Camaro SS
New owner need advice
As most of you have probably already seen a thread similar to this. but im not very good navigating a forum for what i need help with so i figured id put out an SOS. I just purchased a 2010 camaro ss with 60k miles and i want to do a little bit of modding but keep the car my dd. I was thinking the borla atak exhaust, unsure wether to go axle back or full system? also wanted a CAI. very unsure what intake to choose and if i should get a tune with one. i was looking at the CAI brand and it requires a tune but what tuner do i get? was looking at doing heads as well but do i need a dyno run for that or will that tuner work? unsure of the mod path i should choose (headers, exhaust, cai, throttle body, cam?) deff dont have the money for a sc or turbo. also have a friend with a zex kit made for the camaro wants 450 bucks for it? any help would be appreciated.
Stucker152 is offline   Reply With Quote
Old 05-08-2013, 07:06 PM   #2
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
Who told you CAI needs a tune. States pretty obviously hat it does not.
http://www.coldairinductions.com/che...FdCZ4AodCWwAJQ
I like mine.
Wolvie70 is offline   Reply With Quote
Old 05-08-2013, 07:09 PM   #3
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
First off... welcome.
1) If you have an automatic, probably the catback, otherwise the axleback.
2) CAI is a good intake. It does not require a tune.
3) There is no point in doing heads if you haven't done a camshaft. If you get a camshaft and heads, then yes, you will want to go get a dyno tune.
4) Mod path = CAI -> throttle body (if you want one) -> exhaust -> headers -> cam -> heads (if you want to)
If you don't have the money for a turbo, then forget about spraying. You won't have the money to fix your blown motor. It can happen to the best.
Lastly.... This is the method that I use to search this site. I find it superior to the built in search function.
Type the following into google's search bar. This example is for headers.
site:camaro5.com headers
It will limit the results to this site, and get you on your way. Keep reading and mod your knowledge along with your car!
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-09-2013, 12:49 AM   #4
Avenging Orange
Avenging Orange's Avatar
Best advice I can offer is this. Your best, easiest mods for the Camaro are long tube headers, a cold air intake and a dyno tune. Being a newbie or novice to the world of modification.........the best process is to do a lot of reading and asking of questions. Always take it slow and simple till you get you feet wet and understand what does what and how it affects everything else.
2010 Inferno Orange 2SS/RS M6 Black Leather,Sun Roof, OBX Headers, Haltech CAI , non synthetic fluids, Mike Norris tuned 419/413
2015 Ford Interceptor// 2007 Ford F150 XLT 4X4
Avenging Orange: 40 years of not buying into the Hype........and damn proud of it!!
Old 05-09-2013, 05:41 AM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Since you have a 2010, IMHO get a vararam, 1 7/8's or 2" headers that fit your budget like kooks or Tsp's, catback or axle back of your choice (the sound you like the most), 25% under drive pulley and a custom dyno tune.
Then check in later and worry about a cam n heads.
Old 05-09-2013, 06:14 AM   #6
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
if you want to get the best performance and guarantee no check engine lights
1. decide on an intake personally it looks like cai is the best imo
2.longtube headers 1 7/8 to 3 catted if your planning on ever sc or forced induction go with 2 inch primaries to 3 catted then go with a 3inch cat back and a profesional tune dont mess with those handheld things as your only means of tuning that imho is your best way to get horsepower for the money 3. if your talking about cam shaft head plus all the stuff listed above your looking at around 6 - 7 grand installed i have an invoice from a very good shop that did the whole 9 yards and thats what it was but....... in all honesty if your going to drop 6 -7 grand on heads cam echaust intake header and all the other stuff that goes along with it you might be better off spending another 1500 and supercharge it and build around that ..
whats your logic for your first bullet there why would transmission matter on what exhaust someone gets???
coreyaustin17 is offline   Reply With Quote
Old 05-09-2013, 07:16 AM   #7
thahemp
Geek
thahemp's Avatar
That giant tub in the middle of the L99 exhaust.
x = ~x
Old 05-09-2013, 09:16 AM   #8
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
^^^^The last sentence.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 05-09-2013, 09:39 AM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
^^^^^^^. This is what you want to do. Step 1 is always air in and air out. Tune it. See what you got and go from there. if you want more (which eventually everyone does) and can always go to next step. Step 1 builds a solid foundation where future mods will be enhanced by the work you already did. This is a no brainier to follow this path. The next step does get more complicated, and requires a nice chunk of research. Enjoy
Mchlgrrsn is offline   Reply With Quote
Old 05-09-2013, 10:51 AM   #10
Stucker152
dyno
Ok so i purchased the CAI intake and want to get headers but I live in Montana and I am not sure of any dyno companies around my area. I dont want to end up at some hillbilly trailer dyno and trust them that they know what their doing since i obviously dont. Anyone know of any trustworthy tuners in my area? also what throttle body should i be looking for?
Old 05-09-2013, 11:27 AM   #11
SPCBA
Drives: pleather and Chiclets
wish i could help you with a well known tuner. i know that utah and that hippy state west of you have some. You might be a mail order tune candidate as much as i dislike the idea.
As others have said, intake and exhaust are first performance upgrades to hit. by exhaust i mean headers. you might like how the headers sound with the stock catback.
cai is a great choice and does the intended job well. you might want to look at a scoop from adm or apex and a washer bottle relocate kit from rotofab or apex to maximise the cai intake. Happy modding and congrats on a fantastic car.
SPCBA is offline   Reply With Quote
Old 05-09-2013, 12:39 PM   #12
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Smile
Thanks for choosing CAI Inc. for your cold air intake!!!
I am extremely confident that you will be very happy with your choice, we don't have thousands of followers on here for nothing Thank you again for your business and support, and be sure to "Like" us on Facebook now that you are a member of our ever growing regime!
Sales @ CAI Inc is offline   Reply With Quote
