SDTW Custom Wheels & Tires
Old 05-08-2013, 08:21 PM   #1
Zdd
Drives: 2013 Camaro 2SS/1LE/RS
Break-in
Which break in method did you fellow 1le owners use? and what are the results according to you?
Ive read numerous posts about the following method but yet to see any users feedback how it worked out:
Drain the M1 and fill with shell rottela or any good conventional oil (pennzoil or quacker state 5/w30 (no heavier).
Drive the first 25 miles easy and shut down to cool several times and that heat cycles the ring & pinon in the rear diff properly. Then drive relatively aggressive being safe and obeying laws (dont beat the heck out of it) with several wide open throttle runs, but easy on deceleration. NO 5000-6000 rpm down shifts to engine break, just normal.
After app 1000 miles, drain and fill with a good full syn (I prefer Amsoil, Valvoline, Pennzoil over M1, but M1 is still good) and you should have no oil consumption issues and max ring seat for power.
Zdd is offline   Reply With Quote
Old 05-08-2013, 08:45 PM   #2
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Are you serious? Read your manual. Especially about the oil. Good lord.
Sent from my iPad using Tapatalk HD
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 05-08-2013, 08:51 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
After app 1000 miles, drain and fill with a good full syn (I prefer Amsoil, Valvoline, Pennzoil over M1, but M1 is still good) and you should have no oil consumption issues and max ring seat for power. Get our RX catchcan on it ASAP as well.
This is a perfect plan and pretty much what I did. Forget the lawyer written manual, and hard break in for maximum performance with no oil consumption.
You need a hard break in the 1st 500 miles to properly seat the rings, after that your car will be a beast.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 05-08-2013, 08:53 PM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
Actually his plan is much better for proper break-in.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 05-08-2013, 09:11 PM   #5
HighMtnSS
HighMtnSS's Avatar
Drives: '13 AGM 2SS/RS 1LE, 1 of 139
The best break-in is to drive it like you stole it!
This method has worked for me w/no issues what so ever-
'13 Camaro 1LE currently undergoing a very aggressive break-in process
'11 Camaro 2SS/RS
'07 Corvette Z06
'07 Corvette Z51
'04 Corvette Z06
'01 Corvette Z51
'99 Corvette Hardtop
'99 Porsche C2 996
'96 Corvette LT4
'96 Corvette LT1
'95 Camaro LT1
...not to mention many 1/2, 3/4, and 1 ton pickups, both diesel and gas powered!!!
HighMtnSS is offline   Reply With Quote
Old 05-09-2013, 07:12 AM   #6
Zdd
any other 1le owners drive pretty hard during the break-in?
Old 05-09-2013, 07:18 AM   #7
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Mine is not a 1LE but I have 1LE rear end in my SS. I drove factory oil until 1000 miles then oil change to Pennzoil Platinum. Next oil change at 3000 and another at 6000. From now on going to run 6K between changes.
As far as break in first 500 miles did not beat on her or go over 4K rpm next 500 miles did get on her some and did not go over 5K rpm. After that drive her like a bat out of hell when I want to. Not burning any oil and catch maybe a 1/2 a tea spoon in catch can every 400 miles.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-09-2013, 09:45 AM   #8
Casperadub70
Casperadub70's Avatar
Drives: 2014 1LE Camaro, 95 Z28 Camaro
I get my camaro in a few months. The dealership is 40 miles away. When I pick it up and bring it home do you suggest I just take the freeway or do you think taking streets would be better?
2014 1LE 2SS Camaro Recaro seats, Custom Cam, Kooks LT headers, CAI intake, Z/28 Spoiler, Z/28 Belly Pan, Z/28 Brake Air Ducts, Stainless Steel breaklines, BMR Toe Rods and Trailing Arms resulting in 482.49 RWHP
Casperadub70 is offline   Reply With Quote
Old 05-09-2013, 11:42 AM   #9
SC2150
Drive it hard safely for first 500 miles, drain oil and use a good full syn afterwards like castrol syntec, etc. Drain right away and run shell rottela or similar during breaking is better yet.
Following the owners manual odds are you will have oil consumption issue the life of the motor.
Old 05-09-2013, 11:58 AM   #10
SWAG1LE
SWAG1LE's Avatar
Drives: 2013 1LE
Hrrmmmm
SWAG1LE is offline   Reply With Quote
Old 05-09-2013, 12:15 PM   #11
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I find it hard to believe that if the cars are used as intended that you will not have some oil consumption at the 125K/150K mile mark, no matter the break in plan.
gajagfan is offline   Reply With Quote
Old 05-09-2013, 01:04 PM   #12
racerx1214
Drives: 2013 1LE
Drive off lot. Foot to floor.
Repeat.
racerx1214 is offline   Reply With Quote
Old 05-09-2013, 01:13 PM   #13
RoadMonkey
that's how we do it
RoadMonkey's Avatar
Drives: '02 Camaro SS /6spd
I believe that you should drive it like you plan to drive it from the start. Has worked for me so far...
..."It's All Good" -Todd formerly maddog360
-drives: '02 Camaro SS/6spd, SLP
-rides: Harley-Davidson FLHRSE5 110ci-aka Road King
'86 Buick Grand National...mine since '99..a few mod's and never "finished"but I love her...
'13 ZL1/A6 - SOLD..
RoadMonkey is offline   Reply With Quote
Old 05-09-2013, 04:30 PM   #14
Casperadub70
OK so what about freeway use?
