SDTW Custom Wheels & Tires
Old 05-09-2013, 06:51 AM   #1
cam99
cam99's Avatar
Drives: 2012 ZL1
Help, how to turn off all traction control
OK, I'm confused. I want to totally disable the nannies for the drag strip. I have dr's on 18" wheels, so traction is not an issue. I thought that mode 5 did this, but in "testing" I've found it still backs power off in a wheel spin situation. If I hold down traction control button for 5-6 seconds will it turn it all off like my ss did. Even better I've read about pulling fuse 40 &45 (IIRC) to disable abs and stabilitrak. Is this better? Help please. Going to track tonight and want to represent!
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 05-09-2013, 07:00 AM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Same as the SS ... Press and hold the T/C button
Old 05-09-2013, 07:24 AM   #3
cam99
cam99's Avatar
Drives: 2012 ZL1
So if I do that all nannies are off? I don't have to change any ptm modes once I hold down the tc button, or does that shut the ptm modes off also. Not trying to sound like a moron, but I'm going to look like a dipshit if I pull into the burnout box and the car bogs and won't spin. Thanks
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 05-09-2013, 08:51 AM   #4
DrkPhx
DrkPhx's Avatar
Press and told the TC button for 7 seconds until the lights display in the dash. There is also a series of ZL1 specific videos GM released to help new owners. Very helpful and informative. They are stickied at the top of this section.
http://www.lsxtv.com/news/videos-eve...bout-your-zl1/
Old 05-09-2013, 09:19 AM   #5
HDRDTD
PTM mode 5 sets the traction control and stabilatrack for optimal settings for a hard launch on a well prepped drag stip surface.
If you want to turn them off completely and launch it all on your own, do as you did in the SS and hold the button down for 7-10 seconds.
Old 05-09-2013, 09:40 AM   #6
OldScoolCamaro
Yes, press right button for 7 seconds as previously indicated, everythings off, just you and the car. Adjust your RPM launch point according to track conditions as you would have without electronics. That's the best it gets.
Old 05-09-2013, 12:52 PM   #7
hognutz
hognutz's Avatar
Drives: 2013 ZL1
onld the Tc buttom for 5-7 seconds should do it just like your ss. turns off stabilitrack and TC. don't go back into PTM or that will enable combinations of the systems based on mode.
even mode 5 is not everthing off as you have discovered.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 05-09-2013, 06:23 PM   #8
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
press and hold and hold and hold and hold.........there all off.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 05-09-2013, 06:29 PM   #9
KKreme15
KKreme15's Avatar
Drives: C6 Z06
A lot of people, myself included, have run their best without any aids.
KKreme15 is offline   Reply With Quote
Old 05-10-2013, 06:57 AM   #10
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
still running my best time in ptm mode 5. 12.2 @ 117 manual trans
joes407 is offline   Reply With Quote
Old 05-10-2013, 11:06 AM   #11
cam99
cam99's Avatar
Drives: 2012 ZL1
Ran a pair of 11.8's last night all tc turned off on dr's
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
@ PRP with 1100DA
Old 05-10-2013, 02:54 PM   #12
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Well for the OP, I have had no issues with doing a burnout in mode 4 or 5, so I wouldn't worry about that
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 05-10-2013, 03:28 PM   #13
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
I was told to pus the brake down, push the off button until both stabilitrack and TC lights come on and then your ready to roll! It makes a big difference with the power I`m making, no bog with the meth system...
2013 Red ZL1 Auto modded
2015 C7 ZO6 Luguna Blue stock
BeardWS6 is offline   Reply With Quote
