SDPC
Old 05-09-2013, 11:45 AM   #1
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
Need Some Good Cam Advice
I have a 2011 Camaro 2SS and so far I have gotten some lt headers w/ highflow cats, a new k&n cai intake, muffler delete, and some hawk breakpads.. The next thing I was looking to do is get a cam swap for my l99 engine but I am confused on what I need to intall it. Some people say i need to convert part of it to a ls3 and others are saying you have to disassemble the whole engine. If possible can someone make a list w/ links of the equipment/cam/ect that is most recommend for me? Thanks!
P.s. What mods should I do next? I'm getting lowered springs delivered Sunday
DaFisch is offline   Reply With Quote
Old 05-09-2013, 11:51 AM   #2
Retro69
Retro69's Avatar
Drives: 2011 2SS M6 Synergy Green
I would recommend calling Ted at Jannetty Racing. He can hook you up with everything you'll need for the cam swap. Great company to deal with.
Next mod? Pfadt ZL-spec sway bars. I did mine along with drop springs... What a different animal!
Sent from my iPad using Tapatalk HD
480 rwhp ERL 416 ci with JDP Stage II Big Bore Cam
JDP tune, CAI intake, Dynatech LT headers, hi-flow cats
VMAX CNC Ported TB. GMPP Z/28 suspension package
Prothane sub-frame bushings.
Retro69 is offline   Reply With Quote
Old 05-09-2013, 12:21 PM   #3
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Not trying to be funny, but there's atleast 5-7 of these type of threads that are actively currently in this section. Also you can get some of the information you're looking for through the search feature.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 05-09-2013, 03:51 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Search is your friend.
But you have an L99 and you can stay either L99 and keep VVT and get a MAST SS cam with a 32/34/3600 stall get it tuned by rhino79 or you can go Ls3 conversion and get a NF cam.
But you need to remove the heads and get rid of the AFM lifters either way.
Just my .2
Old 05-10-2013, 08:52 AM   #5
BLACK10
BLACK10's Avatar
Hi,
Feel free to give us a call here at Lethal Racing. we would be happy to answer any questions you may have
Old 05-10-2013, 09:22 AM   #6
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
How bout some bad cam advice for a change?
Install the cam backwards and drive in reverse. I hear the intake is a lot better at scavenging than the exhaust.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 05-10-2013, 09:32 AM   #7
Jason 98 TA
Drives: Camaro
With the L99 engine a lot of shops try to sell you VVT delete kits mostly because of a lack ok knowledge on how VVT works & how to tune it. We developed our VVT camshafts using a superflow engine dyno which allows us to make a matching VVT timing table for each rpm point up the entire rpm band. The result is a camshaft that uses different amounts of advance at different rpm points.
There's no reason to remove VVT & give up power. If you'd like to discuss the cam packages & how VVT works give us a call. You simply can't make close to the same average power with a non-VVT camshaft as you can a VVT cam.
A perfect example of how well VVT can work is the VVT-3 camshaft makes 100 flywheel HP gain & still brings power in early thanks to the VVT. Most large camshafts give up some low rpm power because they can't be advanced a lot early in the rpm band. The VVT allows you to do just that & the result is you can bring power in earlier!!
Jason
Texas Speed
www.texas-speed.com
Jason 98 TA is offline   Reply With Quote
Old 05-10-2013, 05:21 PM   #8
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
This is the thread you need...
http://www.camaro5.com/forums/showthread.php?t=125123
c'mon guys.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 05-10-2013, 05:47 PM   #9
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
Now that's funny.
Mchlgrrsn is offline   Reply With Quote
Old 05-12-2013, 10:24 AM   #10
Alvin@PCMofNC
Drives: 2010 IOM RSS
Please let us know if we can help you in anyway. Also please check out our build blogs to see our before and after results, videos, dyno graphs, etc.
Alvin@PCMofNC is offline   Reply With Quote
Old 05-12-2013, 12:42 PM   #11
LS3 SS
LS3 SS's Avatar
If all goes well, I'll be seeing you guys in June!!
Old 05-12-2013, 01:37 PM   #12
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
VVT removal is a mistake, and you are sacrificing better power throughout the whole curve by doing so.
Current bad myths...
VVT Phaser isn't reliable.....complete bs. Ran it on my car up to 7600 rpms a lot of times. Ran it on fi setups.
VVT is a gimmick......complete bs. Sure GM uses it more so for EGR than power, but it is ON THE FLY cam degreeing. With a properly speced cam, it doesn't get any better than that.
My own personaly car runs high 10's on stock heads, with a vvt cam and afm delete. I have no interest in converting an l99 car to ls3. I don't like going backwards with things.
If you have any particular questions just shoot me a pm or email.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
shop.gwatneyperformance.com ryan@gogwatney.com josh@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
