Flowmaster Exhaust
Old 05-23-2013, 09:23 PM   #183
toehead93
Drives: 2014 2SS/1LE
Originally Posted by BullF-16 View Post
What would be the advantage of this RB kit versus the CTS-V 6 piston setup running ZL1 2 piece rotors? Other than weight. Looks like both are comparably priced. Brakes are my next upgrade.
The CTS-V rotors are actually 2 lbs lighter than the ZL1 rotors. The RB rotors are even lighter and to run about 150 degrees cooler which is good. I plan on doingCztS-V setup for more stopping power andbrake ducts later if needed for cooling.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-23-2013, 09:55 PM   #184
SPCBA
Drives: pleather and Chiclets
gonna be honest. with your power you need as much raw stoping power as you can get. weight should be a concern after safety (braking). i am sure you will have some sticky icky tires to and learn to feather that peddle
SPCBA is offline   Reply With Quote
Old 05-23-2013, 10:13 PM   #185
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Jim,
For your ridiculous track animal car we'll be doing the CTS-V six pots and my personal pad compound
Old 05-23-2013, 10:37 PM   #186
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Sounds good to me. After tomorrow i think my suspension will finally be complete!!!! I cant imagine the car will handle better than it does now.
Then on to the brakes.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 05-23-2013, 10:39 PM   #187
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Mmmmmm good reason for RB to do a six piston caliper.
CHMSC is offline   Reply With Quote
Old 05-23-2013, 10:40 PM   #188
JusticePete
VIR Specialist
You have no idea.
Old 05-23-2013, 10:54 PM   #189
SPCBA
You have no idea.
so do these super duper suspensions go to all veterans? ask Bull what a fister/fo is and he will tell you how much we deserve free shit
Old 05-23-2013, 11:16 PM   #190
JusticePete
VIR Specialist
Only the ones I like
Old 05-23-2013, 11:26 PM   #191
BullF-16
BullF-16's Avatar
I was an ALO for 2 years way back in 92. I had to do it to transition from the A-10 to Viper once Myrtle Beach AFB was shut down. So i am quite familiar with FIST teams and FOs. This ALO tour was my AF appreciation tour. Never whined about thing after it was over. I wish some of the things on this car were free, sadly nothing has been
Old 05-23-2013, 11:27 PM   #192
JusticePete
VIR Specialist
I thought I gave you a Coke at Heath's?
Old 05-23-2013, 11:29 PM   #193
BullF-16
BullF-16's Avatar
Thanks Pete, i just spit ginger ale all over my laptop
Old 05-23-2013, 11:30 PM   #194
JusticePete
VIR Specialist
Old 05-23-2013, 11:31 PM   #195
JusticePete
VIR Specialist
Are you already in Fredericksburg?
Old 05-23-2013, 11:37 PM   #196
BullF-16
BullF-16's Avatar
Yep, got in around 1600, went over to see Heath. Plan to meet up at 0830 or so. We can do the ZL1 sway and control arms to start then the 12kg coils and camber plates when they show up. Deb says should be around 1030 - 1100.
