BORLA
Old 05-14-2013, 07:12 AM   #85
The Stig
knows 2 facts about ducks
The Stig's Avatar
Originally Posted by ss/rs-matt View Post
So the RB rotors with stock SS calipers are good or even better than the ZL1/CTSV front set up? Interesting. What pads are recommended with RB?
If you're just counting the rotors - then yes. But because the CTSV has 6 piston calipers, it's not exactly a fair comparison.
Click to view my build thread
Old 05-14-2013, 08:56 AM   #86
Synner
Drives: not stock
Both have pros and cons and both will suck without the right pad and temp range. It would be tough to claim either setup is "best" since people may be looking for different benefits. You can get the RB rotors for the ZL1 calipers as well for the best of both worlds but its not as much of a weight difference, more a metallurgy benefit alone at that point. Cooling ducts for either would be great if you plan on real abuse. I can say my tires are severely overwhelmed with the 6 pistons and track pads, need wider and stickier than stock by far to really use them.
Old 05-14-2013, 09:06 AM   #87
Bornluckee13
I fly
Drives: 2010 2SS, Stick, Cyber Gray
Originally Posted by toehead93 View Post
I priced out CTS-V front calipers, rotors and pads all OEM for $1, 200. No need for rear upgrades and all I need to do is paint them to match. This is all new parts from Amazon and pads from eBay.
Are you sure your looking at the 2009+ supercharged CTS-V brakes and calipers? The older, non supercharged brakes are the same as the stock SS I believe. That sounds MIGHTY cheap!
Originally Posted by kmcd View Post
You mean all those decades I drove a car without an onboard computer, I was cheating death?
There are only two options in life. Fight or flight. Most people run. Almost all people run. But not us. The difference between us and everyone else is that we run towards the gunfire. And that makes all the difference.
Bornluckee13 is offline   Reply With Quote
Old 05-14-2013, 10:13 AM   #88
SPCBA
Drives: pleather and Chiclets
thats the first thing i thought.
Doc brought up a great point. RB has the win in the cooling department by far. the metal and the veins are purpose built to shed heat.
not all of us race or track our cars with 20's or can afford the limited options in 19 inch tire that cant be rotated. i am on 18's on the track with offsets that allow me to rotate and rb was my best option.
SPCBA is offline   Reply With Quote
Old 05-14-2013, 11:11 AM   #89
The Stig
The Stig's Avatar
19" tire options are actually getting better. Oh - you can rotate 19's. When I was talking with Forgeline they mentioned that they run 19x9.5 on all four corners (using 6mm spacers for the front). All the wheels are tucked neatly under the fenders.
Old 05-14-2013, 12:12 PM   #90
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Depends on your driving skill and how often you go to the track. For the vast majority of drivers the stock SS calipers with RB rotors is a fantastic upgrade that will benefit you in every way. If you're an advanced driver like Blake is, then you can use and actually need more stopping power, although it sounds like he did rather well with the stock Brembos and RB rotors.
Let's see what RB comes up with for a caliper upgrade; their caliper/rotor combo may do the trick.
As for pads, here's a link to RB's pad guide:
http://www.racingbrake.com/v/main/rb_pads.asp
When I got mine they didn't have some of the new pads they do now. I have ET500's front and rear. They've worked very well on street and track. Based on what they now have it looks like a decent combo for the new-to-average track day driver would be XT910 on the front and ET500 or ET800 on the rear brakes. That should work for both street and track. You could go with the more aggressive XT960 on the front but I'm not sure those would be so good on the street. If you're swapping pads for track use only, then XT970 front and ET800 rear looks like it would be a great combo. Just don't forget to swap back to your street pads for the drive home. Racing pads have to get hot before they work well and normal street braking doesn't heat them up enough.
Something else to keep in mind when choosing the harder track pads is something has to wear. The softer pads wear out sooner so people think by getting harder pads that saves on brake pads but something has to wear; so harder pads means the rotors wear out faster. RB's 2-piece rotors let you replace the outer rotor while keeping the inner hat so rotor replacement isn't as expensive...another advantage to RB rotors.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 05-14-2013, 12:42 PM   #91
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 05-14-2013, 12:59 PM   #92
ss/rs-matt
ss/rs-matt's Avatar
Drives: 2011 2SS/RS LS3
Good info...thanks! I guess what I'm having a hard time with is JDP sells the CTSV/ZL1 conversion for about $2k (new front 6 piston calipers and bigger rotors). Apex sells the RB rotors for roughly $500 a corner, so $2k. It seems to me the better bang for the buck is the CTSV/ZL1 upgrade. Not to mention I could sell my stock SS rotors and recoupe some of that $2k or use the money to buy RB or ZL1 2 piece rotors for the bigger calipers.
"Want to know whats cooler than your murdered out Honda Civic? ...Any Audi." Daniel Tosh
ss/rs-matt is offline   Reply With Quote
Old 05-14-2013, 01:14 PM   #93
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Old 05-14-2013, 01:28 PM   #94
toehead93
Drives: 2014 2SS/1LE
Positive. These are OE 09+ 6 pot yellow calipers and dual cast rotors from Amazon and OE pass from eBay. the silver calipers are like $30 more. I will share the past numbers later, another forum member has already installed them.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-14-2013, 01:35 PM   #95
toehead93
True but replacement rings are $585 for the front pair which is almost double the cost of CTS-V rotors which is why i am going with the CTS-V upgrade on my next camero.
2010 2SS A6 - sold.
Old 05-14-2013, 02:04 PM   #96
Doc
Doc's Avatar
Get what you feel confident in and works for you. Improving your braking power is a good thing, period.
The CTSV/ZL1 upgrade does indeed improve the braking power of the front brakes. If that is your primary need, as in "I need to pull my car down from 150 to 25 mph going into turn 3" then you need the massive stopping power of 6-pot front calipers. If you only go to HPDE events a couple times a year, but drive your car on the street otherwise, the benefit of the RB rotors are: starting, stopping, suspension performance, cornering, wear-and-tear on tires, slightly improved gas mileage because less power is used to get the car in motion.
An ideal setup would be 6-pot front calipers, 4-pot rear calipers, RB rotors, braided stainless steel brake lines. That's a fantastic street setup and offers incredible performance on the track...at a price of course. Depends on what you actually "need". If you start braking before marker 4 on the track, you'll do just fine with the stock Brembos and RB rotors. If you wait until marker 3 or 2.5 before standing on the brakes, you need the stopping power of 6-pot fronts. What you actually "need" depends on your application and skill level.
You really don't need 6-pots for the street; the stock SS brakes with RB Rotors and stainless steel brake lines is fantastic on the street; stops like glue. Your bigger problem is the guy behind you who is probably going to hit you because he won't be able to stop as quickly as you can. The expense of 6-pot fronts is over-kill.
Track is a different story, but again it depends on what you're doing and your skill level. How often do you do hard all-anchors-out braking? Compare that "need" to how often you accelerate, brake under normal conditions, go around corners, use gas while driving around town.
Sometimes people act like the stock SS brakes are just factory junk but they're not; they ARE Brembos and pretty damned good too. Good enough for the 2-3 times-a-year HPDE or autocrosser....get the RB rotors which will benefit you everyday everywhere. If you're a serious, skilled track driver and intend to track often, you need more braking power. The RB rotors are still a good upgrade but also upgrading to a 6-pot front caliper makes sense because the "need" justifies the expense.
So your decision should be based on what you actually intend to do, and what you'll actually "need" as a result. Don't buy an upgrade just because somebody on a forum said it was "cool"; buy it because it fits what you need for what you're actually doing.
1SS/RS LS3 M6 IBM
Old 05-14-2013, 02:11 PM   #97
Doc
Doc's Avatar
Compared to the cost of tires, brake pads and everything else I'm into on my car I don't mind spending an extra couple hundred bucks every few years for the RB rotors. The weight and cooling advantage is worth it; very cheap actually when you look at the overall benefits and advantages. When I consider the money I've spent; thousands just on wheels, the performance benefits of RB rotors are more important to me than a couple hundred bucks.
1SS/RS LS3 M6 IBM
Old 05-14-2013, 08:30 PM   #98
toehead93
Does anyone know if RB rotor rings will fit the 4piston caliber hub? I have the standard SS RB rotor, i amseriously considering ZL1 upgrade for my new 1LE when it comes in but I may consider addin RB rotors if i can reuse the hub and upraged the rotor ring.
2010 2SS A6 - sold.
