Cold Air Inductions
Old 05-10-2013, 01:32 AM   #1
ATD34
Aseem Ali
Drives: 2010 Black Chevy Camaro SS L99
Quad set-up
What is the main difference between the corsa exhaust on the ZL1 and the Corsa sport cat-back exhaust? Planning on going with the quad set-up on my SS but don't know if i should just install the ZL1 exhaust and just order a new diffuser or should I order the Corsa sport Cat-back along with quad tips and a new diffuser? With the exhaust note be the same?
ATD34 is offline   Reply With Quote
Old 05-10-2013, 01:34 AM   #2
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
NPP dual mode exhaust FTMFWB
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 05-10-2013, 01:49 AM   #3
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
The Corsa setup will be louder than the NPP setup (especially when butterfly is closed), also Stainless Works has a quad tipped setup available in their Retro-Chambered setup, may be worth the look as they have some good products.
Ajdin@A2BMotorsport is offline   Reply With Quote
