ADM PERFORMANCE
Old 05-10-2013, 08:13 PM   #1
johnnyp122
Drives: Camaro v6 lfx
Changed oem manual trans fluid
All I have to say is night and day difference I highly recommend switching to full synthetic 75w-90. I used Lucas and the trans feels like a completely different tranny. 1st to 2nd is like butter. Never gets hung up anymore.
johnnyp122 is offline   Reply With Quote
Old 05-10-2013, 08:56 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Interesting...
Anyone else do this?
Mods:
Roto-Fab Intake, WW Reservoir kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness.
Old 05-10-2013, 09:01 PM   #3
sycraft
COTW 5/06/2013
sycraft's Avatar
I switched to GM Syncromesh, it was a huge improvement. Plus with GM fluids they cannot deny warranty, well maybe they can with my mods....
Chevrolet Performance Synchromesh transmission fluid is designed for GM manual transmissions and is the recommended lubricant for all Tremec brand manual transmissions. It has been formulated with a partially synthetic base for excellent lubrication properties and does not break down after time. Chevrolet Performance Synchromesh transmission fluid can withstand high temperatures as well as cool, low temperatures
Old 05-10-2013, 09:02 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Wow, this seems like a simple way to gain a little tranny upgrade!
Mods:
Old 05-10-2013, 09:31 PM   #5
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
I did the same as you and it's tons better!!
CHMSC is offline   Reply With Quote
Old 05-10-2013, 11:37 PM   #6
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
How many quarts? Is there a stock number for this?
RenegadeSS is offline   Reply With Quote
Old 05-10-2013, 11:53 PM   #7
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
I am very intersted in going this!! Whats everyone using for there tranny fliud? Is it tuff to do? I have never emptied a tranny
nebchevy is offline   Reply With Quote
Old 05-11-2013, 02:33 AM   #8
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Four quarts. Get 5 to be safe. Ask at the parts counter at your local dealer they should have it in stock. Very easy to do. Hardest part is jacking the car up. Pull the fill plug first then pull the drain plug. The drain plug is on the passenger side at the end of the tranny, fill plug is on driver side middle of tranny. Fill tranny till it starts spilling out and you are done. Get a pump for the fluid from an auto parts store.
I also did my rear diff which was pretty nasty and smelly, I would suggest to do both at the same time. Got the gear oil at the dealer as well, it was the heavy duty stuff. I will try and find the part numbers for you guys. Use GM fluid and there is no worries of voiding your warranty.
Old 05-11-2013, 05:46 AM   #9
RenegadeSS
RenegadeSS's Avatar
Drives: Camaro LLT
Thanks a lot. I appreciate everything.
Old 05-11-2013, 06:14 AM   #10
sycraft
COTW 5/06/2013
sycraft's Avatar
only 2 quarts in a V6 car, the Aisen trans does not hold much
Manual Transmission Fluid
1.9 quarts
Old 05-11-2013, 09:01 AM   #11
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged V6
1.9 quarts
What about slip addivtive?...
Lil' Nasty is offline   Reply With Quote
Old 05-11-2013, 09:12 AM   #12
sycraft
COTW 5/06/2013
sycraft's Avatar
Not additive in the transmission. Only the diff gets it
Old 05-11-2013, 09:24 AM   #13
sycraft
COTW 5/06/2013
sycraft's Avatar
Not in the transmission. Only the diff gets it
Old 05-11-2013, 10:48 AM   #14
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
And, it should be mentioned, ONLY the differential in a manual-shift car gets it. Auto V-6's don't have a limited slip rear end. Seems obvious, but you know how threads go.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
