B&M Racing
Old 05-11-2013, 12:08 PM   #1
lcyv
Drives: Camaro 2SS 2011
Help! Camaro dont Start
Al the sudden my Camaro SS 2011 (L99) doesnt start (no modifications).
When I turn the igntion to on position (without starting que engine) the check engine ligh flashes and I can rear the start relay clicking. If I try to start the car the engine doesnt crank.
The codes are i got are as folow:
Any thoughts?
Engine Control ModuleP069EFuel Pump Control Module Requested MIL Illumination- - -
Engine Control ModuleP1682Ignition 1 Switch Circuit 2
lcyv is offline   Reply With Quote
Old 05-11-2013, 12:12 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Did you check to see if any fuses are tripped?
Click to view my build thread
Old 05-11-2013, 12:13 PM   #3
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
battery and/or connections?
Old 05-11-2013, 01:43 PM   #4
lcyv
I will check.
Addtional information I remove the rear seat in order to check the wiring and the pump is making a strange noise. But a mafunction pump could make the engine light flashing?
Old 05-11-2013, 01:43 PM   #5
lcyv
First thing that I check.
Battery and connections are ok.
Old 05-11-2013, 03:43 PM   #6
Chevrolet Customer Svc
Drives: GM Vehicles
Any thoughts?
lcyv,
I'm truly sorry to hear your Camaro will not start. I know this must be a frustrating situation. Were you looking to tow your vehicle to a GM dealership to have this concern inspected?
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is online now   Reply With Quote
Old 05-12-2013, 02:34 PM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
could be your starter.
I had a slow difficult start (put my car in the dealership 4 times for the issue) and the dealership couldn't figure it out.
I purchased a new starter from GMpartsoutlet and had it put on by a friend. Now my car starts up immediately.
Old 05-12-2013, 06:56 PM   #8
lcyv
Tks everybody, it turns out that was a short-circuit in the fuse box that disable the ECM and the MDI did not indentify the issue.
I removed the fuse box cleaned and changed the fuses (20 and 19).
The short-circuit derived from a umidity inside the fuse box (under the conectors). This bring a question, how the water could manage to enter inside it?
Well, again thanks everybody.
